Matrice 210 RTK MISB-compliant video
2059 8 2020-6-12
ejuser-ops
I am attempting to integrate Matrice 210 RTK video into Geographic Information System (GIS) software such as ArcGIS Full Motion Video (FMV)
Does the Matrice 210 RTK produce MISB complient video (i.e. with embedded metadata) when recording in the MP4 format?
Or, am I required to access the flight logs from the Matrice similar to the what's done with a Phantom or Mavic is order to apply georeferencing to video?
2020-6-12
ejuser-ops
Had a couple of grammatical errors in my first post.  I needed to clean it up.
Does the M210 V2 RTK produce MISB complient video (i.e. with embedded metadata) when recording in the MP4 format? Or, am I required to access the flight logs from the Matrice similar to what's done with a Phantom or Mavic in order to apply georeferencing to video?
2020-6-15
BoPRC Drones
Flight distance : 548255 ft
New Zealand
Was there an outcome for this? Am keen to know the answer to this!
2020-7-19
ejuser-ops
I should not have assumed an enterprise level DJI RPAS (i.e. M210) would record video in MISB compliant format. I received nothing back from the community regarding my original post. From the research I have done, the M210 V2 RTK does not produce MISB compliant video. As a work around, I am trying to get the flight records off the CrystalSky device to run ESRI's video multiplexer tool.  It's a far from seamless process.
2020-7-20
MedicFL1
Flight distance : 4358570 ft
ejuser-ops Posted at 7-20 04:04
I think in regards to this data you might be better served in a facebook group.
I am sorry that I cannot remember the group name but others have sought to extract the GEO data from the Exif files also and I believe a simple program is the answer.
If I find it again, I will pass it on.
2020-8-3
fans3536bd28
Have you been successful with this? I'm attempting to do the same thing.
2020-8-31
Brett Cirulis
Hey all, any solutions to this? Looking to do the same soon as well.  I have tried manually doing it on a Mavic but sensor angle isn't recorded in the flight log.  Anyone know if this is the case with the matrice series?
Cheers
Brett
2020-11-13
UnmannedGeo
I don't believe it is currently possible to get true MISB FMV-spec metadata right off of a DJI drone.  However Remote Geo's LineVision software has a way to geotag the video with the DJI Flight Record log TXT file to get at some of the gimbal camera metadata.  Then you can adjust some settings like camera FOV and altitude offset to dial in the where the drone gimbal camera is looking on the map with the field of view.
There is even an option to export a CSV compatible with Esri FMV Multiplexer so you can turn it into MISB-spec FMV if using the Esri GIS software.  Here is a YouTube video on the topic:  https://youtu.be/4DRaNJBBMX0
2020-12-14
fans55f01022
Albania
Hello
Im flying a mavic 2 pro with Litchi software for some video recording and creating the MISB FMV data for Esri ArcGIs,
Does anyone had a problem with camera footprint when upload the MISB video to ARcGIs?im using the same dron with same software and same parameters and sometimes the result is ok,sometimes the video footprint desapear and can not do measurements when open to ArcGIs
2021-11-11
