Aircraft loses RC connection
10608 36 2020-6-12
fans37969c63
Flight distance : 114872 ft
I've had my Mavic Air 2 for four weeks and up until yesterday all flights have had no issues.  During my last two flights the aircraft has lost RC connection, first time it automatically triggered RTH and landed safely.  Second time it only lost connection for about 5 seconds, then reconnected and I flew home manually.  I also found that the duration in the flight data centre of my profile was initially the full time of the flight (approx 6 mins), but when I went to view the flight detail it only shows 1 second duration, then when I exited back to full list of flights it has now reduced the flight duration to 1 min and also changed the distance to 1m and altitude to 0.  I was actually flying at 75m alt and approx 2km dist.
Has anyone had similar issues?
I am using DJI Fly app version 1.1.4.
Thanks
2020-6-12
Geebax
Losing connection is perfectly normal, the radio channel you are using is shared with millions of other devices, one of the most common is WiFi networks. You will find you will get longer range out in the rural areas more so than urban zones.
The flight log is stored in the phone you are using with the RC unit, so if there is a disconnection, the flight record ceases and restarts again when the connection is re-established. Again, perfectly normal.
2020-6-12
fans37969c63
Geebax Posted at 6-12 19:01
Thanks for the reassurance!  I was worried something was wrong, especially as it happened twice.  It was good to see that it automatically RTH though :-)
2020-6-12
Geebax
fans37969c63 Posted at 6-12 19:05
Yep, just what you need, the aircraft does what it is supposed to do.
2020-6-12
FourT2
Flight distance : 595079 ft
Yeah I also got nervous when my MA2 lost connection for a few seconds at about 300 ft in residential area (lots of WiFi access points). Good to know that it will do what it is supposed to.
2020-6-13
小仙女的星巴克
Flight distance : 4657841 ft
Roll back to fly app 1.12. Test it on the same route. I tried it got better distance and signal. I flew in the city full of interference. I had better distance compared with 1.14.
2020-6-13
Hi there, sorry to hear the signal disconnected. Here are some suggestions below, hope it helps.
1. Please always position the antenna properly, the antenna of the Mavic Air 2 locates on the top of the mobile phone holder, please ensure it is pointed directly to the drone.
2. Please turn off other wireless devices during the flight in case the RC's signal is affected.
3. Stay away from electromagnetic interference such as Wi-Fi hotspots, routers, Bluetooth devices, high-voltage wires, high-voltage power transmission stations, mobile phone base stations, and TV broadcast signal towers and so on.
4. Please fly in the open areas, tall buildings, mountains, rocks, and woods may affect the aircraft's compass and GPS signals.
2020-6-13
nik317
Flight distance : 11261506 ft
Switzerland
I have the same issues after the the last update for the fly app .... I have downgrade the fly app and the issues are gone ....
2020-6-13
nik317
Switzerland
nobody else with this issues after updating the fly app to version 1.1.4???
2020-6-13
frankymusik
Flight distance : 27841053 ft
nik317 Posted at 6-13 12:49
I think it is worth to be tested.
But it is not easy to have always the same conditions regarding weather, humidity, flight direction and altitude and so on...
2020-6-13
fans37969c63
FourT2 Posted at 6-13 02:32
Yes, definitely!
2020-6-13
fans37969c63
小仙女的星巴克 Posted at 6-13 02:38
Thanks for the advice, but it appears the fly app v1.1.2 is no longer available.  I'm flying in elevated rural area, not really much interference at all.
2020-6-13
fans37969c63
DJI Mindy Posted at 6-13 02:50
Thanks for your response.  I am flying in an elevated rural area, with very few houses and not much other interference.
Can you please advise how to go back to fly app v1.1.2?
2020-6-13
nik317
Switzerland
fans37969c63 Posted at 6-13 17:06
https://m.apkpure.com/dji-fly/dji.go.v5/download/2043800-APK?from=versions%2Fversion here you go
2020-6-13
fans37969c63
nik317 Posted at 6-13 21:06
Thank you
2020-6-13
nik317
Switzerland
fans37969c63 Posted at 6-13 21:53
Thank you
2020-6-13
Dadaist
Flight distance : 580161 ft
Loosing connection is quite often here in Germany, since high density of buildings (WLan) and also a reduced transmitting power in the EU-Version, so range is sometimes even less than 200m in urban area. It helps a lot to point the antenna towards the air-2, and with the MavicMini a cheap "antenna-booster" (a parabolic mirror) nearly double the range.
But all in all I am satisfied with the range, because I typically do not fly in urban areas - and outside the city even the Mini makes 1-2km, while the Air-2 is good for 2-4km. That's more than enough for my needs (and for the battery capacity...).
Just make sure to properly set the return-to-home-high, since I have the feeling that after every app-update this setting is resetted to factory values.
But, well, yesterday I flew through an broken window into an old factory ruin, when suddenly lost connection - wow, that was a real shoker, only seconds before hitting the roof I could stop RTH-function....
2020-6-14
alexwick
Flight distance : 413934 ft
Do you all get the pop up RC signal interference... I am quit frustrated... All you explanations make sense... But if you fly in the same spot... 2 days in a row... NEVER have any kind of Pop up and it works fine... And then it starts getting constantly signal interference pop-ups not only in the same spot, but everywhere I fly? That seems to much to be coincidence...
2020-6-14
GaryDoug
Flight distance : 1264639 ft
"3. Stay away from electromagnetic interference such as Wi-Fi hotspots, routers, Bluetooth devices, high-voltage wires, high-voltage power transmission stations, mobile phone base stations, and TV broadcast signal towers and so on."
Wow, I was just flying today and day before yesterday in an area right between high voltage transmission towers AND a 1000'  TV transmission antenna. No problems at all in all speed and 4k video modes. Guess I got a good one.
2020-6-14
Andytom69
I tried to use some smartphones, I noticed for example that with the xiaomi mi 10 pro and oppo very strange thing at one point he lost the remote control, while with ipad mini and huawei mate 20, never lost the signal. so I think it's a problem with the phone models
2020-6-14
GaryDoug Posted at 6-14 19:59
Good for you, but please try to avoid flying in this kind of place with high-voltage transmission towers for safety concerns.
2020-6-15
Setan
Flight distance : 1536486 ft
I am having major issues on 1.1.4!  The aircraft is constantly losing connection to the RC.  It just cycles over and over endlessly.  After  hours of screwing around I was able to get the RC and aircraft to firmware 01.00.0250, but it's just cycling the connection issue and the fan goes nuts as it's doing it.
I'm calling support tomorrow.  In the meantime, going to try to figure out how to downgrade the app.  It's really frustrating as one day I was completely fine, now I'm dead in the water.
2020-6-15
waderw
Flight distance : 41785 ft
I downgraded the app and updated firmware and no issues on a long far flight today.
2020-6-15
Hi all, we sincerely apologize for the unfortunate experience with Mavic Air 2, if you have the signal lost issue with the RC, may we have the model of your mobile phone? Could you please sync the flight records and provide us your DJI Account? Additionally, we also need the APP log.
Android device:
Connect the mobile device that has been connected to the aircraft to the PC, and then export the data in the "LOG" folder.
iOS device:
Connect the mobile device that has been connected to the aircraft to the PC, open iTunes, and then export all data under the "Logs" folder.
Once you export it, please upload to Dropbox or Google Drive and post the link here, please also provide the time of the APP log.
It is not recommended to downgrade the APP, we've just released Android DJI Fly V1.1.5, if you use an Android device, please update to this version and try again, thank you.
2020-6-16
waderw Posted at 6-15 21:18
Hi waderw, please check my post in 24#, thank you.
2020-6-16
Setan Posted at 6-15 17:49
Hi Setan, sorry for the unfortunate experience with Mavic Air 2, if you have the signal lost issue with the RC, may we have the model of your mobile phone? Could you please sync the flight records and provide us your DJI Account? Additionally, we also need the APP log.
Android device:
iOS device:
2020-6-16
nik317
Switzerland
DJI Mindy Posted at 6-16 00:59
Android device:
why not downgrade???
with the 1.1.5 its not better the same issues like with the 1.1.4 ....
why you can fix the problem???
2020-6-19
Mirek L
Flight distance : 609724 ft
nik317 Posted at 6-19 14:16
Why downgrade? You are not better off with 1.1.4.
1.1.5 did fix some issues and added some small features but, unfortunately, did not fix disconnect issue.
Downgrading does not make sense unless you noticed something which did work in 1.1.4 and no longer works in 1.1.5.
Mirek
2020-6-19
David Martin Graff
Flight distance : 106566408 ft
That is perfectly a part of flying DJI drones and what makes DJI drones so exceptional is that they have a keen ability to revert to the home point upon every connection loss, either within 3 consecutive seconds disconnected using the controller, or within 10 consecutive seconds if you are disconnected while using just your phone. Unless you don't hear the "Home Point Has Been Updated" prompt before you take off then the drone should in its undamaged capacity fly back and land at the home point.
2020-6-19
Kopernikus
Flight distance : 241263 ft
Switzerland
I have noticed a massive reduction in range since firmware 01.00.0250 (Mavic Air 2). Before that, I was able to fly 2.5 km in a hilly area without breaking the connection. Now the connection breaks off after 900m. I did tests with Android version version 1.1.2., 1.1.4 and 1.1.5 and iOS 1.1.3. The connection has definitely been broken earlier since the firmware update to 01.00.0250. I fly in EU mode, by the way.
2020-6-21
fansba7da676
I don't understand how loss of RC signal can be considered normal and no big deal. It has been happening constantly to me no matter where I fly it and finally it happened. I lost my drone. I lost connection with it relatively low on battery and was not near where we took off. I used the map to try and find it but the last place recorded was directly over water and it must have lost battery over the pond. I went in to look for it but had no luck. Huge waste of money if you ask me and I will not be getting another DJI product. If you can still return your drone and get your money back I would. Losing signal on almost every flight is unacceptable and DJI takes no responsibility. Very unhappy.
2021-7-29
djiuser_1ExoZ9mwDfMD
Flight distance : 1163376 ft
Iraq
Geebax Posted at 2020-6-12 19:01
I had the same problem my Dji Air 2S disconnect from the RC and cant re connect again unless I take the wire out of the phone and connect it again
2022-4-18
VikingVath
Flight distance : 215669 ft
I've been reading these posts for years and it seems the consensus is that DJI has just been getting worse. U can't even get the dji fly app at the play store anymore I had to go through finding it else where. How is that even possible for the biggest drone manufacturer on the planet. It's like logging into Netflix to find out u can't find movies there anymore. Well not really but u get my point, don't get crazy.
2022-12-22
fans11d46349
Philippines
I already have 3 dji drone, but this time i experience lost connection in 10 meters away only, i cannot fly far again.
I dont knkw if my drone is damage or my remote? Or the update. But recently i cannot fly more than 10 to 15 meter, its lost rc connection. Last time i experience crash, this is my first time to crash my drone withour reason, its just fell from the sky. Please help
2023-9-23
fans11d46349
Philippines
VikingVath Posted at 2022-12-22 09:51
Yes! You are right, i was flying like 5 years without issues, but this year, its worse. Crashes, RC lost connection in only 10 to 15 meters away.
2023-9-23
fans11d46349
Philippines
fansba7da676 Posted at 2021-7-29 17:06
Same problem, mine just crash without reason, just fell from the sky. And now before it happened, lost connection like 10 to 15 meters away, its getting worse
2023-9-23
DJI Tony
fans11d46349 Posted at 9-23 19:06
Hello there. Sorry about the experience. It is recommended to get the drone repaired after a crash to avoid the drone incurring further damage. You can contact our DJI support to assist you with the repair procedure here: https://www.dji.com/global/support?site=brandsite&from=nav. You can also use the following link to contact the nearest repair center in your location: https://www.dji.com/global/service/repair/centers. Have a great day ahead.
2023-9-24
