Remote ID Progress - From AMA Government Affairs
712 8 2020-6-16
Cetacean
Flight distance : 2528264 ft
Aloha,
     FYI
Remote ID Progress
The AMA Government Affairs team continues to work toward advocating for a more-inclusive solution to Remote ID.
AMA has been providing sensible recommendations for the hobbyist community to comply with Remote ID since this process started in 2017. The FAA is currently in the process of reviewing more than 50,000 comments that were submitted to the Notice of Proposed Rulemaking (NPRM). We were told that the recreational community had a large impact during the comment period and there were many identified issues with the rule that will need better solutions, which include cost, broadcast abilities, and FAA Recognized Identification Areas.
Through this process, AMA has been collaborating with various security agencies, industry leaders, the DOT, and others to work toward finding a common solution. We believe that the FAA plans to announce a final Remote ID rule by the end of the calendar year. After a final rule has been announced, there will be an implementation period that could take up to three years. This lengthy process allows AMA to continue advocating for a less-extensive solution for hobbyists to comply with Remote ID.
June 5, 2020
     Take care and be safe!
Aloha and Drone On!
2020-6-16
Woe
Flight distance : 4129268 ft
Thanks for the update
2020-6-16
Cetacean
Woe Posted at 6-16 12:25
Aloha Woe,
     Good to hear you found it useful!
Aloha and Drone On!
2020-6-17
Neo Supreme
Flight distance : 76329 ft
Sounds good.  Thankfully the AMA is a big and credible enough organization that can have impact on this issue.
2020-6-17
Woe
Cetacean Posted at 6-17 02:11
Aloha Woe,
You're welcome and stay safe.
2020-6-17
Cetacean
Neo Supreme Posted at 6-17 03:03
Aloha NS,
     The AMA is big and credible as you note, but they are really concerned about this one because this is a security regulation.  There is a lot going on here but the regulation should not be out before the end of the year an then implemented over two or three years.  As much as it is a balancing act, the AMA is concerned enough to plan a lawsuit if it is not fair.  Keep our fingers crossed!
Aloha and Drone On!
2020-6-17
DJI Stephen
Hello there Cetacean. Thank you for reaching out and for sharing these update regarding the Remote ID Progress - From AMA Government Affairs. Great information and thank you for your valued support.
2020-6-18
Cetacean
DJI Stephen Posted at 6-18 20:02
Aloha Stephen,
     Mahalo for the support!  We need to keep up on this or it will come around and bite us.
Aloha and Drone On!
2020-6-18
DJI Stephen
Cetacean Posted at 6-18 23:26
Aloha Stephen,
Hi there Cetacean. Thank you for there reply. You a definitely correct we really need to update each other so that our beloved hobby will grow better in the years to come. Have a safe and a happy flying always.
2020-6-19
