Mavic Mini Aliexpress June 2020 roundup
2347 18 2020-6-17
m80116
Flight distance : 3264131 ft
This month Summer is coming, the first for our little Mini(s) so we better be prepared with the latest goodies available and my favourite go to place is Aliexpress. Here's some nice idea I've selected for this summer.
Mavic Mini Floating Kit
https://www.aliexpress.com/item/4000865095000.html
https://www.aliexpress.com/item/4000370185716.html
Starting from 10.61 EUR / 11,94 USD delivered
What's new compared to the older black kit is that the grey one is lighter (about 30 grams versus 45) and uses smaller floats, thus improving the flying dynamics, but the AC stays a little lower in the water. Not advisable, not DJI approved, but I believe if you have a calm lake with some ducks or some other water surface features it might be a great lasting entertainment. You take off, lower your Mini in the water and wait for your prey to show up. Not only that, I am pretty sure that re-starting the motors at idle you could pretty much make a little hovercraft with it, drifting it back and forward to your liking and hang there for a long time... your flight could last even more than an hour!
Remote Control Exstensible sticks
https://www.aliexpress.com/item/4000619891832.html
https://www.aliexpress.com/item/4000422925416.html
Starting from 10.28 EUR / 11,57 USD delivered
You may choose your favourite design but the concept is there to stay: longer sticks will give you finer control, and you can even decide how fine you want it because they can be adjusted. A very nice addition for those that need finer control over movements.
Reinforced Brackets
https://www.aliexpress.com/item/4001033175804.html
Starting from 3.86 EUR / 4,34 USD delivered
This kit transforms your Mavic Mini into a ramming aircraft. Ok joking aside have you ever noticed that in the unfortunate event of a crash most breakages (beyond gimbal) seem to happen near the arms anchor points? This kit at just 10.5 grams will take care of that. Especially useful if you fly indoors with the Fly more "cage", discharging any additional strain from impact along the braces and onto the body rather than the sensitive articulations.
Silicone Yagi/Uda Antenna boosters
https://www.aliexpress.com/item/4001092194790.html
Starting from 8.09 EUR / 9,11 USD delivered
We all know that Yagi/Udas are a wonderful cheap, effective way of increasing the Aircraft aerial (antenna) performance, but until now the best you could get was a pair of wobbly chipping away 3D printed parts with strands all over the place and leftover colors of some other print. Well seek no more as this might be the definitive answer, a pair of silicone and copper high quality branded adapters that promise to give you a 40% boost of signal.
Grip Handle bracket
https://www.aliexpress.com/item/4000919006394.html
Starting from 9.52 EUR / 10,72 USD delivered
Well... I am not sure how many will need this one but when I've done my own homeworks I discovered the Mini has Steadycam like stabilization much better than my GoPro Hero 6 Black, and the most per pixel detail of all my other small cameras, so why not use it as a hendheld? This pistol shaped grip might be the perfect solution if you need a close to Osmo Pocket quality footage but don't want to invest your money into something you'd only use a couple of times. And if you combine the Mini's footage with an audio recorded from a capable Mobile Device the Remote is linked to, you can really have one of the best stabilized videocamera for an amazing little price. If you need there's even a mount to combine the Mini + RC and use a standard 1/4 BSW screw mount https://www.aliexpress.com/item/4000521226317.html
LED Marking Lights
https://www.aliexpress.com/item/4001056757267.html
https://www.aliexpress.com/item/4000620417598.html
Starting from 3.29 EUR / 3,70 USD delivered
Summer is coming and with that longer days, vacation and outdoor recreation... so why not have a late evening fun with the Mini. While I don't endorse blind flights you could certainly find yourself landing at dusk where a help from a pair of nice marking lights could be quite useful for landing, if anything they may put a good show off. There are models for all pockets, from simple button battery operated models that promise up to 24 hours of light to USB reachargeable lithium ion battery ones. And if you really want to be serious even strobe lights that you can see from several hundred meters of distance.
Necessary disclaimer: I am not sponsered or endorse any particular product, I usually go to Ali because it's Alibaba, the source of everything. It's like eBay and Amazon combined, and I don't like middlemen. I like to buy straight from the source, so no Geek, no Wish... no other nonsense for me. I want the best variety and the best price. I usually pick my items besed on price in the first couple of pages (standard sorting). And for those who might say: aah but Wish offers me fastest EU local delivery: it's on Ax as well... it's just a little bit overwhelmed by the amount of stock there is, but if you dig just a little deeper you can pretty much find a ship from EU for many comparable items.
2020-6-17
Ralle
Flight distance : 11289 ft
Finland
2020-6-18
comrant
Flight distance : 983025 ft
Grip Handle bracket...
have you actually used this? I would highly recommend NOT doing this, as the mini has no active cooling source, and mine has shutdown and been extremely hot after just a few minutes of it idling on my desk.
2020-6-18
m80116
Bracket? No, but I have used my makeshift contraption to make a comparison video and... Mini on the landing gear (search Ax), landing gear strapped to a wood panel, I've never had a problem. And with never had a problem I mean in a well ventilated sunny day outside touching the underbelly of the Mini felt just warm... not very warm or hot like when you do firmware upgrades that you have to forcefully load it w/ it on and motors out, and I resort to keeping the Mini next to my laptop HS exahust to cool it off.
2020-6-18
DJI Stephen
Hello there m80116. Thank you for reaching out and for these information and accessories for the DJI Mavic Min that you have share with us. Just a reminder that please be careful in using 3rd part accessories on your DJI Mavic Mini. These 3rd party accessories might affect the said DJI drone's performance when in use. There is a possibility that these 3rd party accessories will be able work. However, since it's not optimized and tested by DJI we cannot guaranteed the stability of the said 3rd party accessory if it will work all the time with no issues and might void the warranty of the said DJI product. Thank you and have a safe flight always.
2020-6-18
virtual
Flight distance : 4897142 ft
Czechia
I'm using extended sticks and I like them. Silicone signal booster sounds like a good idea to me...
2020-6-19
Richard Hopkins
Flight distance : 923406 ft
DJI Stephen Posted at 6-18 23:12
Hi, DJI Stephen Why doesn’t DJI provide more accessories for the Mavic Mini so we don’t have to go to 3rd party suppliers I am sure every one here would buy them! Thank you!
2020-6-19
JM.REYES
Flight distance : 84423 ft
Richard Hopkins Posted at 6-19 04:00
Yes sir, well said. I just thought the same. Let's see if DJI answers ...
2020-6-19
DJI Stephen
Hello there Richard Hopkins. Thank you for reaching out and for sharing your insights with regards to this matter. Rest assured sir that DJI is continuously creating and testing multiple accessories for all or DJI products and drones to be added on the recommended accessories in the future. Thank you for your understanding and support.
2020-6-22
Montfrooij
Flight distance : 2560453 ft
I have bought some stuff for my MP, but seldomly use it.
2020-6-23
sv3n
Flight distance : 35833 ft
Montfrooij Posted at 6-23 01:59
I only bought some ND´s for MM. But other than that, I also have no idea what kind of stuff I´d mount on it..
I´m also concerned about the weight of all accessoires, I mean not only cause of the 250 grams, but I´d also be afraid the extra stuff weights too much for my MM to carry.
2020-6-23
Montfrooij
sv3n Posted at 6-23 02:38
Stick with the drone.
And only buy when 100% sure you need it.
I lost some money in the first weeks 'believing' I needed the extra acc.
2020-6-23
Durlano
Flight distance : 90453 ft
North Macedonia
Yagi/Uda antenna is for 2.4G or 5.8G?
2020-6-23
m80116
Those mentioned in the article are 5.8 GHz. 2.4 GHz are less popular since they work on CE model only.
2020-6-25
harmonmonic
Very interesting post, especially about аloating kit. One already drowned..
2020-10-6
A J
Flight distance : 14044580 ft
Some cool little accessories there - thanks for sharing
2020-10-6
amir_KING
Flight distance : 372992 ft
Nice finds!
2020-10-6
MariellenJaffe
Pakistan
The Information you shared above is great. I have been reading all you shared here. In this you explained everything very well. If i want any further guideline we will contact you here https://forum.dji.com/thread-218324-1-1.html https://gosloto.co/
2022-4-5
MariellenJaffe
Pakistan
ascascsacasc
2022-4-6
