Mirek L
Flight distance : 609724 ft
hallmark007 Posted at 6-18 11:35
It has been recommended that you turn off Bluetooth and WiFi on your device. Trees forest also play a big part in blocking or soaking up signal.
And I suppose your device could be the problem, so try turning off BT and WiFi see if this helps and or switch device to see if this makes a difference.
hallmark007,
This is not frequent (happens to me once every several hours of flying).
I doubt that signal betwen RC and AC is lost since yetesrday I was 20 metres away with no obstacles between me and AC and no interference whatsovere (no civilization around). Signal was prisitine.
In addition, lost signal between RC and AC does not result in DJI Fly app going blank and switching back to the main screen. This is probably related to DJI Fly bug which has not been fixed since 1.1.2. And, perhaps, affects only certain mobile models (Samsung?).
However, I will make sure that Wifi and Bluetooth on my phone are turned off and, next time it happens, I will try to control AC to see if it responds (I am quite positive it will - but we will see).
Mirek
