DJI Fly App does not install on Samsung Galaxy TabA
12100 23 2020-6-19
TimothyD
Flight distance : 5236 ft
The DJI Fly App needed for my new Mavic Air 2 and Mavic Mini does not install on a Samsung Galaxy TabA.  You can't even download it from the Play Store to the tablet.  Which seems odd to me.  My TabA is the latest model/version.  The DJI Fly app installs just fine on my new Samsung Galaxy S20 Ultra phone.
I was successfully able to download the DJI Fly install file and sideload it to my TabA with no issues.  The DJI Fly app on the TabA does recognize both the new Mavic Air 2 and Mavic Mini.
Has anyone else done this successfully and if so have you had any issues flying?
The DJI Go 4 app installs and operates just fine on my TabA for my Mavic 2 Pro, Mavic Air and Spark.  So when is DJI going to update the DJI Fly app so that it can be downloaded and installed via the Google Play Store onto the TabA?
2020-6-19
Hotrod in Daytona
I use the TAB S5E.  I know its more $$$$ but the screen is so much brighter which is what your spending the dollars on.
2020-6-19
TimothyD
Hotrod in Daytona Posted at 6-19 13:19
Sounds great!  However, I am not asking about the TAB SSE.  I am asking about the TabA...
2020-6-19
lannes
Flight distance : 4465 ft
Since you have managed to install DJI Fly on the Tab A, the only way to check if it works is to test fly it.
2020-6-19
Hithere, the DJI FLY APP was developed based on the 64-bit platform. The minimum request of installation environment as below:
1. Requires Android 6.0 or above.
2. Available ROM is 2GB and above.
3. Supporting ArmV8 64-bit architectures (64-bit processor).
Please check whether your tablet meets the requirement above. If it is not working, there might be a compatibility issue, it is recommended to use the phone in the recommended list for a better experience: https://www.dji.com/mavic-air-2/downloads
2020-6-20
TimothyD
Thanks...however, that did not answer my question.  Also, I don't see any list per the link you sent
2020-6-20
TimothyD
DJI Mindy Posted at 6-20 02:46
The Samsung Galaxy TabA 8 does indeed meet the installation environment requirements.  As stated, I can download the .apk file from DJI.com and sideload it just fine on the Galaxy TabA and it all works.    If the TabA did not meet the installation requirements sideloading the .apk file would fail right?
  • So...why does DJI not allow the download and install of DJI Fly app to the TabA directly from the Google Play Store when it does for the DJI Go 4 app?
  • Also, why doesn't DJI support ALL newer Android devices that meet the installation requirement.
  • And lastly... when will DJI get off their ass and start supporting these devices??
2020-6-23
3JdadTsi
Hello Timothy.
You said that you download and installed DJI Fly Pilot to your TAB A and side installed it.
Did it work? If yes, how did you get it installed?
Thanks.
Ayo
2020-11-10
3JdadTsi
How come DJI  has not issued an update software patch to enable Samsung Tab A to be used as a monitor for Mavic Mini?
Ayo
2020-11-10
Devearl Leo
I paid over $140 for the Samsung Tab A! Why the hell doesn’t it load?? Not compatible???
DJI, FIX THIS!!!!!
2020-11-12
Devearl Leo
3JdadTsi Posted at 11-10 22:57
Ayo
THIS IS INSANE!!!
2020-11-12
Devearl Leo
3JdadTsi Posted at 11-10 22:51
Hello Timothy.
Yes, please explain. Thanks!
2020-11-12
RussellBDrone
Flight distance : 319760 ft
My tab A had same " not on Samsungs Google Play Store " issue. side load as well and everything is working.. bought a sunshade and screen is plenty bright...
2020-11-23
djiuser_2XXQHk8YMtEI
Hi, i have an Samsung tab a  10.1inch ,i donwloadit it from DJU ,but it is not possible to install.The DJI Go 4 works very well with my mavic pro2 it it possible that that the Fly app not work with 32bit Samsung Tab a?
2021-1-24
kwpodolsky
I have a Samsung Tab A 8" (SM-T380) and if I go to Play.Google.Com, the DJI Fly app doesn't even show up.  Go 4 does as does others.
SO... I went to the DJI site, used the QR Code and downloaded the APK file.
Tried to install it and got an UNKNOWN ERROR.
Why is it I can run DJI Go 4, Litchi, Dronelink, Kittyhawk, AirMap, FT Aviator and others, but I can't install/run DJI Fly???
2021-3-28
GaryDoug
Flight distance : 1122201 ft
kwpodolsky Posted at 3-28 07:16
The FLY app needs a 64 bit system. Some Tab A's are not 64 bit.
2021-3-28
djiuser_QKhb68IfDJ2n
GaryDoug Posted at 3-28 14:56
Thanks to all for helping us Galaxy TAB A peeps. PhoneDB says my Samsung SM-T580 WIFI Tab A is 64bit.  Android My Device says 2gb ram but can't see if 32 or 64 os
I downloaded the current dji fly apk from dji. Per instructions I made permission to run 'untrusted apk' .. THE app installs to about 75% and reports : App not installed.
Running Android 8.1.0 O-r-e-oooooo
Maybe I've turn a system apk off ?
Any help appreciated.
2021-4-3
Hey Mates ! Dji Fly apk lists supported haaaardware.
If read ... Galaxy tablets do not appear .. Phaablets and phooones .. not tablets
      - what .the ...  ?
Whatever. How do I cast my samsungs20 to my wifi tablet (hey happy DJI doesn't mandate wearing a mask while flying)
2021-4-3
GaryDoug
djiuser_QKhb68IfDJ2n Posted at 4-3 18:13
I don't know why so many users expect the Tab A to work when DJI does not say it will. The T580 processor is plenty powerful but it has NO magnetic sensor, so part of the display will NOT work That may be why DJI does not list it. Android version doesn't matter a lot, 64 bit devices have been supported since Android 5 and DJI says FLY needs Android 6.
2021-4-4
djiuser_CPyQPgFyXNNk
RussellBDrone Posted at 2020-11-23 07:45
I have the the 21 so i can fly, but i picked up this little tabA to try a bigger screen. Obviously having the same issues you guys have had. So what is this "side loading"? I gotta try this or im gonna eat the cost of this damn tablet
2021-9-26
Mobilehomer
Flight distance : 2466411 ft
djiuser_CPyQPgFyXNNk Posted at 9-26 00:54
Try downloading from the Galaxy store.
2021-9-27
djiuser_RqZ5wHbx6jq7
Mobilehomer Posted at 9-27 05:35
This option worked for me on Galaxy A51. Many thanks
2021-12-30
djiuser_Da6vZtj0LkXM
Switzerland
Devearl Leo Posted at 2020-11-12 19:06
DJI, FIX THIS!!!!!
I am on your side DJI FIX FIX THIS I HAVE A TAB A TO
1-22 03:56
Bob Brown
Flight distance : 3772907 ft
I am on the same boat... this tablet is plenty powerful enough... Android v10. Sideload ends in "Not Installed" for me.
5-7 02:30
