twilight
Flight distance : 2113606 ft
Romania
I thought i knew well how return to home works, but every day is a good day to learn!
I watched the movie 5 times trying to understand why it's doing that thing! And then I downloaded the MAVIC AIR 2 manual! )
"Failsafe RTH
If the Home Point was successfully recorded and the compass is functioning normally, Failsafe RTH
automatically activates after the remote controller signal is lost for more than 11 seconds. The aircraft will fly
backwards for 50 m on its original flight route, and then enter Straight Line RTH. The aircraft enters Straight
Line RTH if the remote controller signal is restored during Failsafe RTH.
After flying for 50 m:
1. If the aircraft is less than 20 m from the Home Point, it flies back to the Home Point at the current altitude.
2. If the aircraft is further than 20 m from the Home Point and the current altitude is higher than the preset RTH
altitude, it flies back to the Home Point at the current altitude.
3. If the aircraft is further than 20 m from the Home Point and the current altitude is lower than the preset RTH
altitude, it ascends to the preset RTH altitude and then flies back to the Home Point."
That's cool when you accidentaly lost connection taking your drone after a building, she tries first to come back 50 meters to try to regain control over her. It's nice! |
