Labroides
Flight distance : 9991457 ft
It was the first time I ever had an inaccurate RTH landing ( it was going to land about 5 ft. off).
I would like to know if there is a logical explanation why an uncalibrated newly ND filtered Gimbal might throw off the accuracy of the RTH or was this experience just a coincidence?
It had nothing to do with your gimbal etc.
If the RTH autoland was 5 ft off, it was not using or not able to use the Precision Landing feature and used GPS only.
GPS is not pinpoint accurate and will usually put the drone within 6 feet or so most of the time and sometimes even further off.
Precision Landing uses optical technology and would not be affected by the filter or calibrating anything.
I don't remember hearing my lady friend in the controller say " The home point has been updated" on the first flight. Do you know if it is possible to confirm whether or not the home point was updated for a particular flight?
Yes, it's possible to confirm by examining your flight data.
But in the case you described, your drone obviously recorded a home point very close to where the drone landed.
+/- 5 feet is perfectly normal when you only have GPS for RTH autoland guidance.
