Phantom 4 take off from moving boat
127 6 7-1 02:16
Alexios
Greece
After many years of flying on land, I wanted to try my luck at flying from a moving boat at sea... it was a complete failure!
While out at sea (it was a calm day with minimal waves) on a small 30 ft. passenger boat I set up my Phantom 4 with my crystal sky monitor in GPS mode.
I waited to see if there were any IMU/GPS/COMPASS errors and everything was fine.
I next proceeded to start the motors, and immediately, before I gave any throttle, the drone began to "compensate" for the sligh rocking of the boat and started spinning the motors erraticly. The drone then proceeded to topple over and fall onto the ground.
I then tried hand launching in ATTI mode, but the same phenomenon seemed to occure, which in the end is logical since the drone wants a stable solid surface for take-off.
My question is, is there any way to disable sensors so the drone doesn't try and "auto-correct" before take-off while on a "rocking boat"?
Any other tips that will help me to take-off succesfully while on a boat, even if the boat is not moving under-way?
Thanks!
7-1 02:16
Labroides
Flight distance : 9991457 ft
Hand launching in atti mode should do what you need.
It's what I do when flying from a boat.
In P-GPS the drone will try to hold position which can cause problems but in atti mode it shouldn't want to fight you.
7-1 02:43
DJI Stephen
Super Moderator
Hello there Alexios. I am sorry for the trouble this has caused and thank you for reaching out. I will be posting a link where in you can see some tips on How to Fly Safely Over Water. Thank you and fly safe always.
https://store.dji.com/guides/how-to-fly-safely-over-water/
7-2 01:44
rwynant V1
Flight distance : 3098196 ft
Flying from a boat.....PHHTTT.....
7-2 18:41
Cetacean
Flight distance : 2397178 ft
Aloha Alexios,
     Here is a good video - and the boat was moving!
     Take care and be safe!
Aloha and Drone On!
7-3 01:28
Mark Weiss
rwynant V1 Posted at 7-2 18:41
https://youtu.be/17RWWVnFij8
Looks like he threw the drone into the air and it took flight.
7-10 16:12
Labroides
Mark Weiss Posted at 7-10 16:12
He just released it and climbed a little and the boat sailed away from it.
7-10 18:45
