MA2 Strong Wind Warning and Considerations
4352 22 2020-7-4
Rustic17
Flight distance : 2733760 ft
This just popped up on my YouTube homepage... I found it very interesting.  The wording of the alert probably needs to be changed.  The key thing to remember, if you're new to DJI drone flying, is the Low Battery RTH triggers based on distance away from the RC and the power the app thinks would be required to RTH....this computation is based on a NO-WIND scenario. If the RTH is into the wind, your drone might not make it back home.  Most experienced drone pilots will fly out into the wind so they have a tailwind return.  Either that, or start home with 10-30% extra power than they normally do.  Fly safe!!!
2020-7-4
GaryDoug
Flight distance : 1264639 ft
Really? I flew my MA2 in 20+ MPH winds today (upwind and downwind repeatedly) and had no warnings even when going below 30% battery 1/2 mile downwind. Landed with 15% left.
2020-7-4
Rustic17
GaryDoug Posted at 7-4 21:03
I don’t think the video was faked...I just wanted you all to know about an alert that might pop up that at face value could be a little unsettling.
2020-7-4
GaryDoug
Rustic17 Posted at 7-4 21:15
Didn't think it was faked, just maybe a bit conservative. Thanks for posting it.
2020-7-4
InTheReeds
Flight distance : 347103 ft
Just curious, how do you know the computation is based on a no-wind scenario?
2020-7-4
Rustic17
InTheReeds Posted at 7-4 21:27
Read the last caution at the top of page 15 in the manual.
2020-7-4
Rustic17
GaryDoug Posted at 7-4 21:21
Yeah....I think the issue is when the wind speed approaches the max speed of RTH or the max speed of the drone.  In your case, you still had some power to overcome the wind.
2020-7-4
Ian in London
Flight distance : 8330187 ft
Thanks squire.
You're right; the auto low-battery RTH is indeed constantly recalculating its trigger point based on the distance from the home point but makes no consideration of wind.  Thankfully as you say, it's usually pretty conservative and will allow for a head wind but if you're flying far away and it's a strong wind, then yes, watch out...
I made this video to demonstrate the fact that despite the wording of the warning, it will still go into RTH mode, and it will make up some of the speed even against a wind that is stronger than the spec'd max RTH mode speed of 12 m/s.
Cheers,  Ian
2020-7-4
Ian in London
Hi again Gary
These warnings pop up at any time in the flight and do pop up quite regularly for me in the Fly App for the Mini and the Air 2.  The wording implies you have no RTH functionality, but that's not actually the case, hence the video....   When they occur, the whole handset vibrates....
2020-7-4
Mortensldk
Flight distance : 132592 ft
Denmark
Thanks for sharing
2020-7-5
Rustic17
Nice, informative video, Ian.
2020-7-5
Woe
Flight distance : 4129268 ft
Thanks for sharing. Good info for new pilots.
2020-7-5
JJB*
Flight distance : 12225059 ft
Rustic17 Posted at 7-4 21:41
Hi Rustic,
I read this caution in a different way ; when the wind is too high and the drone cannot fly against the wind it wiil never reach home automatically.
I think i agree with you that DJI calculates the time to fly back home (thus auto RTH) without actual wind values, let me think of a way to test that out!
cheers
JJB
2020-7-5
Rustic17
JJB* Posted at 7-5 07:29
Hi Rustic,
You say "never"...the manual says "may not".  It may still be able to fly into the wind but the energy (battery) required may not allow it to get back to the HP.
2020-7-5
Droneflier
Flight distance : 1811322 ft
South Africa
Thanks for the info will come in handy
2020-7-5
JJB*
Rustic17 Posted at 7-5 07:44
in my case (situation) i said :  "never & cannot fly the against the wind"  = true.
But ofcourse it is may not for all wind speeds in wich the drone can have positive ground speed values towards home.
cheers
JJB
2020-7-5
GaryDoug
2020-7-5
GaryDoug
Ian in London Posted at 7-4 23:46
Hi again Gary
Really? I have never seen it with the MA2, but many times with the Mini.
2020-7-5
Smashey1
Flight distance : 173422 ft
Good to know, makes sense really.
2020-7-6
NiNo Brown
Flight distance : 33942267 ft
Nice video, thanks Ian...
2020-7-6
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for sharing this informative video a very nice find. Just a friendly reminder to please follow the prompt to reduce altitude when seeing this notification to ensure a safe return of the drone while doing RTH. Thank you and safe flying.
2020-7-6
kiminx
Flight distance : 149032 ft
Indonesia
so the conclusion is :
1. flyback manually using sport mode
2. lower altitude
2020-7-6
Montfrooij
Flight distance : 2560453 ft
Good find!
2020-7-13
