Tablet - Lenovo Tab M10 FHD Plus
15937 18 2020-7-7
David Geens
Flight distance : 213934 ft
Belgium
Tested today the DJI fly app on a Lenovo Tab M10 FHD Plus (tablet) used my smartphone as hotspot.
Works without any problems.
Processor Soc : MediaTek Helio P22T (MT8768)
ARM architecturre :  ARMv8-A
Cluster Type :
ARM Cortex-A53
GPU:
PowerVR GE8320
Display : 10.3 inch (1920x1200 px , 220ppi)
System: Android 9
2020-7-7
GaryDoug
Flight distance : 1292802 ft
Good for you. But keep in mind that not every drone will work with a certain tablet just because it works with the Fly app and Mini. My first tablet worked with the Mini but not with the  MA2 even though they use the same app.
2020-7-7
DJI Stephen
Hello there David Geens. Thank you for reaching out and for sharing your experience in using the Lenovo Tab M10 FHD Plus on your DJI Mavic Mini and with the DJI Fly application. Thank you for your support and fly safe always.
2020-7-7
David Geens
Belgium
GaryDoug Posted at 7-7 20:22
Which tablet did or did you use?
2020-7-8
GaryDoug
David Geens Posted at 7-8 04:42
I use a Samsung Tab A, specifically model SM-T290, for the Mini. I use an ASUS ZenPad Z8S P00J 16GB for the MA2 (or MIni). Both drones use the DJI Fly app, but that model Samsung will not work well for the MA2, possibly too slow.
2020-7-8
David Geens
Belgium
GaryDoug Posted at 7-8 06:42
The samsung use a snapdragon 429 ( 4x ARM Cortex A53, Quad-core CPU ) for the MA2 it is to slow.
I think , if it exists a octacore it can be work.
The lenovo use the same Cortex A53 architecure on a Octa-core base CPU
The Asus use a Snapdragon 652 (  4x ARM Cortex A72, 4x ARM Cortex A53, Octa-core )
The Cortex A73 have more futures as the A53-Cortex.
I think with the ARM8v and a octacore cpu with Cortex A53  or higher.
And with a cpu from
Qualcomm 450 , Qualcomm 652 or MedieTek Helio P22  ( almost same as the 450 from Qualcomm only a bit faster. )
The DJI fly app works fine. BUT !!!! IT IS NOT A GUARANTEE  ;-)
If Samsung do not give the specs of the cpu , DO NOT BUY.
They use for the same model different cpu's.
2020-7-9
djiuser_dutsqPH09vbe
Slovenia
Thank you. I have Dji Mini 2 and i would like to buy tablet so i will buy Lenovo Tab M10 FHD Wi-Fi Plus (ZA5T0189BG). I hope it will work.
2021-1-27
djiuser_XHPAHRxz5W6m
UPDATE: DJI Mini 2 - Lenovo Tab M10 FHD (2020)  This tablet is working great for my mini 2 with the DJI Fly app! just wanted to confirm. I got the basic 32GB storage model with 2G RAM.  So far no issues after about 5 flights.  Distance of 3000-4000ft with an altitude between 200-300ft
Super affordable tablet with a 10" screen. Would recommend. Must download the app from dji website
2021-2-7
Flaming
Flight distance : 250541 ft
djiuser_XHPAHRxz5W6m Posted at 2-7 03:06
thx for the info , but there is no compass in this model.
i am still looking for a compatible android tablet WITH a magetometer
2021-2-8
steamship
Flight distance : 229180 ft
Russia
I'm on the lookout for a 10" tablet to use with my mini 2 and here in the UK the Lenovo is within my max budget of £150. As you're in the US, can you confirm if your model has 4G in it or not? In fact, do you need 4G at all, as I can't find anything definitive about it?
Also, mainly directed at user Flaming but if you know the answer, what is the significance of the tablet not having a compass as he mentions in his post? In this current environment where you can't go into a shop and buy something, take it home, test it and bring it back for a refund the same day, I need to be certain about what I'm buying beforehand, and the Lenovo seems the best option at the moment as everything else starts from £200 up.
2021-2-13
Flaming
steamship Posted at 2-13 04:06
Not having a Magnetometer sensor mean that the aircraft orientation indicator will not work.  If you are going to buy a tablet you want every features to work right ? So this tablet doesn't have a Magnetometer.   Pass.
https://m.gsmarena.com/lenovo_m10_plus-10360.php
2021-2-14
steamship
Russia
Flaming Posted at 2-14 02:02
Many thanks for that explanation. Now that I know what I'm looking for, it looks like my 'budget' is going to be around £200.
2021-2-14
Flaming
steamship Posted at 2-14 05:06
By the way , a missing magnetometer sensor will not prevent you to use the drone and fly. But you have to put more efforts flying it because you are missing some valuable telemetry.
2021-2-14
djiuser_7RpssnecsLkP
Flight distance : 22349 ft
Thank you to DJI for the Magic mini, I'm using my Lenovo Tab 10 with the Fly app.  Thank you for the last update
2021-2-22
YAKKER61
Flight distance : 17014 ft
Can you tell me which cable you used for the connection please
2021-4-3
David Geens
Belgium
YAKKER61 Posted at 4-3 06:19
I used a USB adapter cable ( OTG )
2021-4-7
JJB*
Flight distance : 13955751 ft
Flaming Posted at 2-8 06:47
Xiaomi PAD 4  does work great
2021-4-8
djiuser_gZqezyG8U7TZ
Flight distance : 26814 ft
(mini 2) Im using the Lenovo yoga tab 11 -8 gigs of ram 256gb storage-  Using Samsung note 10 plus as my hotspot. Works great! If you hurry you can get one at best buy, open box in excellent condition for around $250 w/tax. Used with Mavmount 122-235mm scout prime adapter w/lanyard. (Around $90 total after 10% off for email plus shipping.) Still less than an iPad and it works great with Ru! (Adobe Premiere Rush) also lightcut (dji's app) and a few others that were tried. Have a good sunhood (some small mods required), high speed USBC cable and nice camera/drone backpack that fits and protects everything perfectly. Just holler if your looking for links or model numbers. Wish there was more accurate information when I first started flying, hope this helps someone save some time, money and aggravation aggravation. .
2023-8-25
Chris Wilke
They might have stopped this because I am no longer able to use this tablet since 1 month ago. When I downloaded it, it says only available for older products and closed.
2024-11-25
