tmkoehn
We received a Phantom Pro 3 from a friend who no longer wanted it. When I try to update it to the latest firmware (1.11.20) it fails. The first time it was updating for around 15 minutes, and then it emitted the long solid beep and would not stop. So I shut it off an tried again. Now it fails within a minute of turning it back on. I have formatted the sd card to FAT32 and put the .bin file on the card, still no luck. Here is the output ...
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Result: Abort.
Packet: P3X_FW_V01.03.0020.bin, P3X_FW_V01.04.0010.bin
Result: Forbidden.
Multiple version firmware bin files are detected. Please delete the redundant bin file.
========== 2015.10.21 13:54:03 =====================
Result: Forbidden.
========== 2015.10.21 14:01:42 =====================
Result: Forbidden.
========== 2015.10.21 14:29:02 =====================
Result: Forbidden.
========== 2015.10.21 14:35:02 =====================
Result: Forbidden.
========== 2015.10.21 14:35:43 =====================
Result: Forbidden.
========== 2015.10.21 14:42:43 =====================
Result: Forbidden.
========== 2015.10.21 14:55:05 =====================
Result: Forbidden.
========== 2015.10.21 14:56:12 =====================
Result: Forbidden.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.10.21 16:32:28 =====================
Result: Abort.
========== 2015.10.21 16:34:40 =====================
Result: Abort.
========== 2015.10.21 16:38:24 =====================
Result: Abort.
========== 2015.10.21 16:43:33 =====================
Result: Abort.
========== 2015.10.21 16:44:28 =====================
Result: Abort.
========== 2015.10.21 16:46:02 =====================
Result: Abort.
========== 2015.10.22 12:37:01 =====================
Result: Abort.
========== 2015.10.22 12:45:17 =====================
Result: Abort.
========== 2015.10.22 12:48:21 =====================
Result: Abort.
========== 2015.10.22 12:54:28 =====================
Result: Abort.
========== 2015.10.22 12:58:58 =====================
Result: Abort.
========== 2015.10.22 13:01:46 =====================
Result: Abort.
========== 2015.10.22 13:24:22 =====================
Result: Abort.
========== 2015.10.22 13:25:05 =====================
Result: Abort.
========== 2015.10.22 13:43:20 =====================
Result: Abort.
Result: Abort.
========== 2015.10.22 15:03:15 =====================
Result: Abort.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.11.0020.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Any ideas on where to go from here?
thanks in advance!
