Range Issues - PHANTOM 3 SE
2024 32 2020-7-13
Dr.dem
Hi everybody,
I have recently bought a second handed phantom 3, and I updated it to the last version (I cant remember which one right now), I tested it in a forest, and the result was not good enough, it flies well, but the range is really bad (around 250 meters, after that It loses signal) I bought a big antenna, to increse the range thinking that was the problem, but I tried this last week and it was a fail again... Somebody knows what is going wrong?
Thank you in advance!
2020-7-13
JetSam
Flight distance : 3462946 ft
the short range of your device is due to the fact that you fly in CE (eUROPA)
el escaso alcanze de tu aparato se debe a que vuelas en CE ( eUROPA)
2020-7-14
JetSam
You need a version of Dji go in FCC mode, the difference is brutal, I reach 5 kms in open field until I lose signal
Necesitas una version de Dji go  en modo FCC , la diferencia es brutal , yo alcanzo 5 kms en campo abierto hasta perder señal
La solucion es sencilla, no dudes en preguntarme si necesitas mas guia ....
2020-7-14
JetSam
Welcome to the Forum Dr.dem
2020-7-14
JetSam
Otro largo vuelo sobre las nubes , entre la niebla , 5 kilometros ida y 5 kilometros vuelta
2020-7-14
DJI Paladin
Flight distance : 318 ft
Hi. I am sorry for the trouble this has caused. With regards to this concern. Something may be causing the interference in the location. Kindly please try flying the drone in a different location with less interference like radio tower, power lines and metal structures. In addition, I have posted an official DJI video tutorial for the best practices when flying the drone. Please keep us posted for further assistance. Thank you.
2020-7-14
Dr.dem
JetSam Posted at 7-14 00:08
Hi jetsam, thank very much you for those tips, how could I install fcc dji go version? Where could I find it.
Thx you a lot buddy!
2020-7-14
JetSam
DJI Paladin aiming correctly dont solve the problem mate  , you know Phantom 3 SE got a very short distance running in CE MODE , only solution is run IN FCC , gREETINGS !
2020-7-14
Dr.dem
DJI Paladin Posted at 7-14 00:17
https://www.youtube.com/watch?v=P7M9JtfVwQE&t=45s
Hi dji paladin, I'm completely sure about i have no interferences there, this location is a field completely bald actually there is no antenna or electrics wires, we flied a xiaomi fimi, and this drone gave us around 2km of range, but this phantom couldn't reach 280 meters, I don't know if it was due to the fact that the ce mode but in europe it is not 300meter the legal distance to flight is over 500 meters.
2020-7-14
JetSam
The P3SE's, depends on where did you buy it from, can have 2 factory settings, the FCC and the CE by default. The range of this bird in CE mode is around 5-600m (not urban area obviously). FCC mode takes you 4-5 km away, depends on ....  My Videos are proof of i am talking about ,I would never have reached those distances flying in CE mode (eUROPA)
2020-7-14
JetSam
2020-7-14
Dr.dem
How could I change CE mode into fcc mode? I can't find it on the dji go app menu....
2020-7-14
JetSam
Dr.dem Posted at 7-14 00:50
YOU CANT ... iT IS A FCC MODE mate
2020-7-14
JetSam
Cuando estes en FCC veras en la wifi de la aplicacion que en el canal de 2,4 Ghz TENDRAS 11 CANALES EN VEZ DE 13 QUE tenias modo CE
2020-7-14
JetSam
11 CANALES en la banda de 2,4 Ghz significara que estas en modo FCC ( Maxima Potencia como en Usa)
13 canales signigicara que estas en Modo CE eUROPA ( eXtemadamente baja potencia)
aunque este aparato funciona a 5Ghz , yo jamas he podido cambiar a 2,4 Ghz
2020-7-14
JetSam
Beberias desisntalar el mod, e instalar la version Normal de Dji go de nuevo para estar en CE ( 13 CANALES EN 2,4 gHZ )
2020-7-14
Dr.dem
... Well if I can't change to this mode then I have a nice paperweight.... Luckly I bought it used and it didn't cost me too much... But what a ..... Well I'll try to buy a xiaomi, it looks pretty better than this phantom.
Thank you buddy, I am totally disappointed but at least I have solved this issue.
2020-7-14
JetSam
Dr.dem Posted at 7-14 01:00
This device has always had European users crazy with this matter ...
2020-7-14
JetSam
Phantom 3 se is a awesome machine , but in FCC MODE
2020-7-14
JetSam
You should uninstall the mod, and install the Normal version of Dji go again to be in CE (13 CHANNELS IN 2.4 gHZ)
2020-7-14
Dr.dem
For sure... But if I can't change to this mode, it is just a chicken.... , actually I have chickens with more flying range...
2020-7-14
JetSam
Dr.dem Posted at 7-14 01:06
LOL
2020-7-14
JetSam
I USE THIS MOD FROM 2017 , i really love this mod , I was about to throw my phantom 3 SE  down the gorge ... I GIVE thanks to CREATOR of this nice solution
2020-7-14
JetSam
I have not used the original version again ... I had great distance problems, constant loss of signal at a short distance ... it was crazy to fly like this ...
2020-7-14
Dr.dem
What mod? Still have some hope to don't put it into the wardrobe and forget it.
2020-7-14
JetSam
Dr.dem Posted at 7-14 01:13
FCC MOD  to get 4-5 kMs distance
2020-7-14
JetSam
it's in the first video that I put
2020-7-14
Dr.dem
Where could I get this mod???
2020-7-14
JetSam
the mod change from CE TO FCC , SIMPLY
2020-7-14
JetSam
Dr.dem Posted at 7-14 01:17
Phantom 3 SE - Distance Test 2019in the video description
2020-7-14
Dr.dem
All right now, I'll try to get and test this program, we will see, what could go wrong... Now I can't fly this if I broke the drone this won't be a great loss...
Thank you dude you have helped a lot!
2020-7-14
JetSam
Dr.dem Posted at 7-14 01:24
you r welcome !!
2020-7-14
JetSam
Dirty Bird Posted at 7-14 18:33
Excellent flight there.
Thanks Captain !
2020-7-15
