LarryTru
Flight distance : 458944 ft
Hello, while setting up a somewhat complicated mission outline, I encountered one point which I can't move to the desired spot. The outline turns red when I try. I don't see anything unusual about that particular point being moved to where I want it. I can move other points without running into this problem. Moving this point would put it pretty close to the "S" (start) of the flight path, but I don't know why that would matter. The algorithm decides where the start should be. Right?
Thanks,
Larry
