Jumpy Video
stac57
Running some test om my P3P and the video isn't that great.
Moving up and down there isn't a problem but once in place and rotate around for a full veiw images is jumpy as if it's trying to catch up to the Quad.
Any ideas how to fix this?
my gopro on my P2 was so smoth.
2015-6-19
aburkefl
Flight distance : 78612 ft
Change mode from FPV to Follow?
2015-6-19
nosarafern.aol
Costa Rica
mine is the worst..
i have an original Phantom (phantom 1) with a zenmuse gimbal that gives me a flawless video clip (using the Hero3)
my P3P results in an extremely jerky side to side motion akin to shaking your head from left to right while you're trying to see something...
i hope this is firmware issue and not a hardware issue...
i am bummed.
2015-6-19
smittyvette
I had what I think might be the same condition you guys are talking about.  My gimbal was doing some crazy shifting on side to side motion.  I found that the Vision Positioning System was turned on....I turned that off and all good.  I don't plan on flying indoors so I should not ever need it.
Best of luck....hope you guys have success in figuring it out.
2015-6-19
cmmettler
I thought I had the same issue - but it was just play back issues on my old Mac Book.
Better computer plays video fine
2015-6-20
pixeleyz
Flight distance : 1066076 ft
The P3P's 4K video requires a fast computer with a very capable graphics card and a display at least 4K in resolution.  I have all that, been editing 4K video for a while.  But the P3P's camera falls short, especially for one called "Professional".  The slow 60mbps data rate is no where near what is needed for 4K video. DJI dropped the ball on this. My $800 Panasonic Lumix fx1000 has a 100mbps data rate, and the video is excellent (granted, it can't fly without help from an aircraft).  If you want proof that the P3P's camera falls short, try this.  Go up to about 150 feet, fly over a corn field (or most anything else) on a day when there are cloud shadows.  The cloud shadows, for some reason, are a real problem for the P3P's camera.  It does a really odd artifacting thing; the cloud shadows don't move with the rest of the video.  They stand still for 7 frames in a row, and only move on the 8th frame.  It is so odd and jerky, really sad.  Try it, it will amaze you and tick you off too. It ruins the video.  I've tried it a few times with perfectly repeatable results, does it every time.  Somebody please confirm that you see this too! Thanks.
2015-7-14
dewulf.harry
Flight distance : 86348 ft
i had jumpy video on my p3 adv with video settings 1080P50fps, changed it to 1080P 24fps and it runs smooth now
2015-7-15
