M4cr0s
Flight distance : 1404308 ft
Norway
fans7d2141d0 Posted at 7-26 12:34
thanks for taking the time to write such a detailed response, much appreciated and some good points which I hadn't thought regarding viewing distance.
I think I would go with canvas as it solves the framing issue.
Cheers
No problem. Bear in mind, if printing this large, I would do test prints of a crop of the picture you are planning to print, and then view it at a reasonable distance, at a size around A3/~"11.69 x "16.53 to get an idea if grain, noise and resolution is acceptable to you. Such as this.
To eke out as much quality as possible, I would definitely process raws from the drone, export as 16bit tiffs, stitch in for instance Microsoft ICE or Hugo. Preferably export the image with a couple different projections, typically stereographic and spherical, from the stiching software and see what looks/works best. Choice of projection and cropping also has a significant impact on the resolution of the end product. Then do final adjustments in Photoshop or similar.
