griffdude13
Flight distance : 53507 ft
Hey guys,
So my ideal setup is using the a6400 on the Ronin SC with the Atomos Ninja V and the ability to electronically pull focus via the USB-C to w/micro usb adaptor. The pull focus works great. However, if I try to use this with the Ninja V connected as well, the Ninja does not receive a signal. Technically, it does, audio comes through, but the screen remains blank. Only unplugging the Pull Focus Cable resolves this, but then I can't use pull focus, which is frustrating. I want to use both. I can only assume this is a Sony issue, but has anyone in this situation found a workaround?
