Motor error
2650 8 2020-7-26
Dmitri_Rm
Czechia
Good day,
We purchased the robot a couple of days ago for our educational center, after 4 minutes of use, an error of the left front motor was displayed on the screen.
I try to turn on / off, disconnect the cable, change ports.  None of the above helped.
To make sure that the matter is in the motor, I connected the same motor to another robot (I have 5 of them), the motor did not work.
And to the robot that had an error, I connected motors from other robots.  Other motors on this robot were functioning.
Thus, you can 100% say that the problem is in the motor.
ERROR
ERROR
Has anyone had a similar problem?  Does this mean that it is necessary to change the motor.
Thank.
UPD.
after calibrating the motors and changing the port, a new error appeared.
2020-7-26
BGA
I am pretty sure you will have to RMA it.
2020-7-27
puma1969
Flight distance : 2569 ft
Same error on both of my ROBOMASTER S1
Had them for a little less than a month ?  Did the same thing took everything apart put back together nothing.
Am hoping dji will just exchange both of my Motors.
2021-1-5
puma1969
BGA Posted at 2020-7-27 08:18
Purchased the Robomaster s1 a little less than a month ago. already got bad rear right motor, "check connection " I did.  re seated them and nothing. am trying to get  a replacement and possibly buy an extra motor just in case this would happen again. any advise ?
2021-1-6
puma1969
did you ever get this issue resolved ? did you have to go out and buy new motors ?
2021-1-6
fansb0ff4d31
Did anyone resolve this? Having the same problem.
2021-5-6
Optimus3
Republic of Lithuania
Having the same problem now. Are there any ways to solve it or just change the motor? Its funny because its also hard to find new one...
2021-8-14
Haloking1212
Optimus3 Posted at 8-14 11:20
you might just need to change the motor, I accidentally drove mine into deep water and im having that issue took apart gonna let it dry and put it back hope it works
2021-8-14
Optimus3
Haloking1212 Posted at 8-14 18:41
Have you tried to run "motor addressing"? Does other motors run?
2021-8-14
