cookinghusband
Flight distance : 41463 ft
if the tilt is correct have you try to turn the Ronin-m on? If your camera is light the balance only have to be marginally correct, not perfectly correct and it still work fine. I believe balancing the camera to stay centre is what is correct? Just switch it off quickly if it do not sound right after operation start |
