Mavic Mini won't turn on
19085 35 2020-8-1
kk95
Flight distance : 68766 ft
Portugal
Hi,
After a few days without turn on the drone, randomly it now won't turn on. It turns on the light when charging but it does not react when the power button is pressed (sometimes it does turn all 4 leds but does not turn on). Any help?
Regards,
Luís
2020-8-1
Cetacean
Flight distance : 2528264 ft
Aloha Luís,
     Be sure you are turning on the Mavic Mini correctly.  You press the on button for a half second and then press again and hold down the button for a second press for two seconds.  That is in the manual.
     Hope this helps!
     Take care and be safe!
Aloha and Drone On!
2020-8-2
kk95
Portugal
Cetacean Posted at 8-2 02:29
Aloha Luís,
Hi Cetacean,
I've been trying that. Still nothing. The only response I get back from the system is the four leds turning on (not even blinking) for a second.
2020-8-2
m80116
Flight distance : 3264131 ft
Time for a warranty call.
2020-8-2
kk95
Portugal
m80116 Posted at 8-2 06:00
Seems like it
2020-8-2
kk95
Portugal
Hi all,
Don't know how, but apon insisting it turn on. But bad news, it doesn't turn off....
2020-8-2
m80116
interesting... intermittent fault, like the power button isn't properly soldered onto the PCB or it's faulty.
2020-8-2
Cetacean
kk95 Posted at 8-2 02:38
Hi Cetacean,
Aloha Luís,
     Before you go that route of making a warranty call, try pressing for one second followed by a one second press and try again with a one second press followed by a two second press.  Everybody's time estimates are different but time itself is quite precise.
     It may just be that your estimates are slightly off.  That has happened to me before and even with DJI products.  When humans meet machines, humans often get confused - I know I did!  It eventually worked out.
     If playing around with the presses still does not work out, then contact DJI and send it in.  But, they do turn on and off with the same kind of press routine.
Aloha and Drone On!
2020-8-2
kk95
Portugal
m80116 Posted at 8-2 20:54
Hi,
I don't believe it's PCB related... I would believe it would be more the microprocessor's fault (even more wierd), since it seems to not count or react to the seconds that I press the power button. I also believe it's not software related since I the flashed the drone with DJI Assistant.
2020-8-3
kk95
Portugal
Cetacean Posted at 8-2 22:07
Aloha Luís,
Hi Cetacean,
The problem is that it doesn't even blink the leds when I press the power button, showing the battery state. Yesterday, I was able to reinstall the firmware on the drone as I told in the previous post, but it did not change the sistem's response. Also, I was able to turn on the drone but hadto forcefully shut it down, since it still didnt react... Also, as I Electronic Engineer, meeting a new machine is no news to me
Thank you for the support.
Regards,
Luís
2020-8-3
DJI Stephen
Hello there Luís. I am sorry to know and to read that you are having issues with your DJI Mavic Mini. Since you have the correct process in powering on the said drone ( press the power button once , then press again, and hold for two seconds to turn the DJI Mavic Mini on or off ). Can you please try posting a sample video of the said issue for us to be able to see and assists you further? Thank you.
2020-8-3
kk95
Portugal
DJI Stephen Posted at 8-3 01:37
Hi,
https://youtu.be/1V1zXOhD8gk
This was before I got it working and while charging. Also I was not trying to turn it on but simply to get it blinking.
Regards, Luis
Edit: Will upload a video before sending it to the warranty later today.
2020-8-3
Cetacean
kk95 Posted at 8-3 01:22
Hi Cetacean,
Aloha Luís,
     Every journey starts with a few steps.  Sorry to hear you got a lemon.  DJI Stephen should be able to help you resolve the problem.
Aloha and Drone On!
2020-8-3
kk95
Portugal
Cetacean Posted at 8-3 03:40
Aloha Luís,
Hi Cetacean,
Thank you for the kind words. Hopefully I'll resolve things soon.
2020-8-3
kk95
Portugal
Hi all,
Don't know what happened but today, after work hours, the drone decided to work. I was going to film it not turning on the leds but it is fine now. Problably gonna send an e-mail to support anyway to check if it is worth send it back for a check-up.
Regards,
Luís
2020-8-3
DJI Stephen
kk95 Posted at 8-3 01:43
Hi,
Hi there Luis. Thank you for the reply and for the video link you have posted. Since this issue is happening on your DJI Mavic Mini. I would recommend you to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We have a professional team that will do there best to check the said DJI drone and give out the best resolution for this issue. We hope to hear from you soon and looking forward to resolve this issue as soon as possible. Thank for your understanding.
2020-8-4
kk95
Portugal
DJI Stephen Posted at 8-4 01:21
Hi Stephen,
Will do. Thank for the support.
Regards,
Luis
2020-8-4
DJI Stephen
kk95 Posted at 8-4 01:24
Hi Stephen,
Hi there Luis. You are very much welcome and if you have any other concerns or inquiries with DJI. Please feel free to post it here at DJI Forum. We are here to help and support you. Thank you.
2020-8-5
Jason Kibaru Ngugi
Kenya
Hi all
I have a similar issue with my DJI Mini 2 not powering up !
this seems to be a manufacturer defect very stressing .
Am Based in Nairobi , Kenya I cannot use my drone now
2021-3-20
kk95
Portugal
Hi Jason,
I had to send it back to DJI. It was a manufacturer defect...
I'm sorry to hear that you had the same problem.
2021-3-20
Satstream
Flight distance : 392024 ft
Got the same problem with the Mavic mini, no chance to turn on. Mavic mini is exactly 1 year old. I sent it to the EU Service Center in the Netherlands for repair!
2021-3-21
kk95
Portugal
Hi Satstream,
Sorry to hear that! Good luck
2021-3-21
Rushi31
India
same problem
https://drive.google.com/file/d/1zsdA20dj6mzgomXjs2u8ERGaak6ckUCo/view?usp=sharing
Mavic Mini is not starting all 3 battery are full and press an press and hold for 4 sec
v01.00.0400
plz help me
2021-4-24
cowolter
I had a similar issue. It turns out it was a faulty battery... it wouldn't charge. Wasnt the charger.
Got an exchange and the new bird has successfully logged its first flight.
2021-4-24
Rushi31
India
cowolter Posted at 4-24 02:55
I have 2 Mavic Mini but 1 is fine I have that problem with 2 mini I have used all 6 battery with both mini all batterys are fine
2021-4-24
kk95
Portugal
Hi,
In my case, it wasn't the battery... It was the "Power ESC Board Module".
2021-4-27
djiuser_zbkZGxwwi8LX
My drone just tried to go on fire after starting
2021-10-18
djiuser_JfU6IXZ3plWe
Switzerland
Same problem here. I've not used the drone for couple months and now the drone does not start-up. I've tried different timings for pressing the button, but unfortunately only the lights go on and not the drone itself.
2021-11-5
Rosie Hewitson
Hi can someone help. I'm in england, I have tried opening a repair request but it seems to be in a loop that sends me back to the menu page. I have tried ringing the UK number but apparently due to ' ooany simultaneous calls I can not be connected'
2021-12-1
Maxi3D
Flight distance : 307621 ft
It could be dirty connections on your battery terminals.
2021-12-1
creatavision
Flight distance : 5702 ft
Cetacean Posted at 2020-8-2 22:07
Aloha Luís,
That would be good, except that in my case, it has disconnected when it was all connected. So when I try and press for 4 sec to reconnect, nothing is happening. I think this product has a heap of faults, but will keep reading. So far, all I am finding is same issue with many people!
2022-2-17
creatavision
djiuser_JfU6IXZ3plWe Posted at 2021-11-5 10:49
Same with me, although it's only a matter of weeks. The drone does zippo when I try and turn it on and it has disconnected from the control panel. So, am trying to reconnect it, but pressing the button for 4 sec, 10 sec, any seconds, nothing happens.
2022-2-17
creatavision
cowolter Posted at 2021-4-24 02:55
We've got three batteries...none of them make any difference. It's a shame that trouble shooting has to go across the drone, and batteries. Assuming my batteries are all x 3 good, narrows it down to the drone.
But we are in Australia and exchange rules are good here...looks like this one will be going to landfill
2022-2-17
benjam
I had this exact problem. Turned out I wasn't pushing the power button hard enough. It clicks but needs a good hard press beyond that to engage. Possibly some corrosion over time on the switch contacts?
2022-4-8
TOM-DJIAUS
Flight distance : 522995 ft
Hi all,
I seem to be having the same issue. My Mavic Mini has decided it won't turn on or charge batteries when they are inserted. At first I thought it could be the batteries themselves, but after using a friends 3 Battery Charging Hub both batteries charged perfectly to 100%.
When inserting them back into the drone, no battery indicator lights show up when clicking the on button. If a charging cable is inserted the battery indicator lights show 4 lights constantly on, but as soon as the cable is unplugged the indicator lights turn off.
Do you think this is the same Power ESC module defect as @kk95 ?
2022-5-23
TOM-DJIAUS
TOM-DJIAUS Posted at 5-23 16:44
Hi all,
EDIT:
I sent my DJI Mavic Mini into DJI for repair. After carrying out a damage assessment, DJI found that 'the Core Board Module was malfunctioned which caused boot and shutdown related fault'. The repair quote was a new Core Board Module @ $74 USD + Repair Service Fee @ $65 USD bringing the total repair to $139 USD.
This sounds like the same issue as the original poster of this thread. Interesting to see if anyone else has had a similar problem?
2022-5-26
