Osmo Action - New Features Removed
252 15 8-2 02:14
Spillihpnevets
I updated my firmware a while back when Hyperlapse was introduced and it worked fine, the next time i switched the camera on all of the new features from the latest update were missing.  I left it for a bit and updated to v1.09 and again everything was fine for a while until i switched on and found everything new has disappeared again.
I'm not sure if this is a common thing with an easy fix but cannot seem to find a solution, i cannot update the firmware again as the device itself shows the latest version.
I have emailed DJI support but wondered if anybody else had the same issue and managed to resolve it?
Thanks
Steve
8-2 02:14
DJI Susan
Hi Steve, could you please provide me with some screen snaps of the shooting modes you have on the Osmo Action? The modes can be checked and change by tapping the icon on the lower left of the screen. Thanks.
8-2 23:26
Fishycomics
This is what you see in the camera fw 1.09.00.10
  • Video
  • HDR Video
  • Slow Motion
  • Timelapse
  • Hyperlapse
  • Photo
Quick Switch  area full list of Modes
  • Video
  • HDR Video
  • Slow Motion
  • Timelapse
  • Hyperlapse
  • Loop recording
  • Photo
  • Burst
  • AEB
  • Timed
What do you see also when p ressing the lower left icon  in video, photo, and if you set customs up?  With the modes unchecked, you would see the full list  wit hthe lower left icon checked /unchecked.
If DJI allowed a refresh firmware, maybe it is time they should Unlock it   so we can  have some control then forced with issued camera's?   Also  a factory reset  cam be tried, remember your settings if doing so.
8-3 04:06
Spillihpnevets
8-3 06:09
Spillihpnevets
8-3 06:09
Spillihpnevets
8-3 06:09
Spillihpnevets
The photos above show the firmware version and options in the menus.
I have tried factory reset and this did not change anything.
Video is missing hyperlapse and loop recording, there are also no live stream options.
8-3 06:13
Fishycomics
By all means you best get with the chat customer svc.   see  what they say and let us all know.
8-3 09:43
Spillihpnevets
I had already raised a ticket with support but posted here to see if anybody had seen something similar.
I received a reply today with a link to the firmware version 99.99.99.99 which will probably allow the version to be re-flashed.  I will check it later.
8-4 04:07
Fishycomics
Spillihpnevets Posted at 8-4 04:07
Could you PM that to me Please? I appreciate that.  I pm'd you.
I seen a few posts of this Issue no resolution was offered.
8-4 04:09
Spillihpnevets
Sure, I will make sure it works first then update you and send the Wetransfer link, it expires in 7 days so you would have to download the .bin file and keep it somewhere.  If the link doesn't work for you I will send you the .bin file.
8-4 04:12
Fishycomics
I do hope yours is resolved,   fingers crossed. Big thank you.
8-4 09:12
Spillihpnevets
Thanks, i Pm'd you.
Everything seems to work great for now and the firmware version on the device is showing 00.00.00.00 and prompting me to connect to MIMO and update firmware but I'm going to leave it unless I encounter the same issue again at which point I will try to update via MIMO.
I'm wondering whether its possible to just change the version number in the .bin file to force a re-flash.
8-4 11:21
Fishycomics
Spillihpnevets Posted at 8-4 11:21
Thanks, i Pm'd you.
I just loaded, and  can not manually load fw 1.07.00.01 for example, or  manually load fw 1.09.00.10 either, I will see if I can  with the Mimo app  load up.  I got a straight forward video. made.
I loaded fw99.99.99.99  the update was like 6 seconds done. I can reload it as long as I have the file and I have fw 54.48.254.43
8-4 11:24
Spillihpnevets
No worries, try the link that I sent you and if you cannot access it I will send you the .bin file
8-4 11:28
Fishycomics
Spillihpnevets Posted at 8-4 11:28
thanks. I was able to minipulate the name. will tell later.
8-4 12:29
