My 15$ Mavic Mini modded case
840 10 2020-8-10
raulvolador
Flight distance : 4771427 ft
Hi friends,
As I bought a basic Mavic Mini (not Fly More Combo edition) I needed a case. After some research I found this chinesse Mavic Mini case for about 15$. It's sold online under many different brands: Anbee, Wellbuy, Tineer, Penivo, HRB, Soyan, AKD Steel...
This case looks great, it's durable and well designed. Small size but enought room for Mini, up to three batteries and lot of accesories.
Unfortunatelly, Mavic Mini controller don't fit well. A bit of modding is neccesary.
In this video I teach you how to mod this case by adding a shoulder strap and cutting some foam.
This case is working great for me. I hope you like it !
R.
2020-8-10
DAFlys
Thats a good value little case.  .
2020-8-11
A J
Flight distance : 13926112 ft
Good looking deal
2020-8-11
DJI Stephen
Hello there raulvolador. Thank you for reaching out and for sharing this carrying case for the DJI Mavic Mini. Great find and thank you for your support.
2020-8-11
Woe
Flight distance : 4129268 ft
Very nice
2020-8-11
m80116
Flight distance : 3264131 ft
I do believe there's something missing from that case.
Depending on the orientation you keep your case stored and how prolonged the bottom propellers of the folded legs remain pinched between the case and the drone weight, the props themselves could actually get warped and lead to undesirable flight problems.
I think you should improve on the design by protecting the props during storage (both rear and front), the original Fly More Combo case has a bump on the bottom in which the Mini rests atop, leaving the props free in mid-air (if you stored your Mini correctly), same applies to the top (front) props which do not touch the ceiling of the case when closed as a bump almost as large as the body comes down and stabilize the drone, while providing in the lower part an empty space to accomodate the folded together front props and motors.
2020-8-11
Lucas775
Flight distance : 50642090 ft
I got the same case.
2020-8-11
raulvolador
m80116 Posted at 8-11 08:49
You are very right. Mavic Mini propellers are very fragile. I always use a propeller holder before storing into case.
I'm using this DIY ribbon & velcro prop holder:
2020-8-12
m80116
It's a good thing I remember you now
But I still believe you need some kind of bump underneath the relieve the weight from the bundled props.
2020-8-12
raulvolador
My Mavic Mini log shows more than 10 hours airborne. It's still using original propellers.
I always carefully store drone folded using my velcro & ribbon prop holder.
I'm very proud to claim I have never had any 'Motor Speed Warning' due to warped props.
R.
2020-8-12
Montfrooij
Flight distance : 2560453 ft
Looks nice
2020-10-25
