Fixing a corrupted H265 MP4 from M2P
1529 12 2020-8-12
DieselE
Flight distance : 25935 ft
Just tried DJI Fideo Fixer 4.1 but it wont process 1 corrupt file i have out of my Mavic 2 Pro's 59 other good ones. Its H265 encoded 10 bit log and wrapped as an MP4 and i think the app only does H264.
The file is over 1Gb so there is good video in there - how can I fix it to make it readable pls?
Thanks
2020-8-12
DAFlys
Have you tried running it through handbrake?
2020-8-13
DieselE
DAFlys Posted at 8-13 00:55
I had tried Sorenson and VLC but not Handbrake.  Sadly its too corrupt for it - but there is over 1Gb of H265 goodness in there, somewhere!
2020-8-13
DAFlys
DieselE Posted at 8-13 01:28
[view_image]
Any idea what caused it to become corrupt?
2020-8-13
DieselE
No idea.  60 files that day all good - not this one in the middle.  Nothing unusual at all or codecs exchanged or anything.  I did get an SD card error at the time but have a good one I hope, that is quite new!
2020-8-13
DieselE
Ramon Posted at 8-13 04:41
HOLA.DieselE,para recuperar el archivo mete la tarjeta en el drone enciende todo como si fueras a volar,pon a grabar unos segundos ,saca la tarjeta y mira si es ta el archivo de video.saludos
Entiendo.  My Spanish is good enough to understand that   Gracias
2020-8-13
DieselE
Ramon Posted at 8-13 04:44
eso suele ocurrir si apagas el done o RC cuando estas grabando.saludos
Es un possibilidad... Critical battery and I had to fight it from crash landing itself automatically - was just in an empty field full VLOS and needed 2 more minutes!  It really fought to do its own landing thing.  Aprendiendo...
2020-8-13
DieselE
Ramon - no trabaja.  It didnt work unfortunately.  On my big TV camera if you have a corrupt file - not closed properly at end of record usually - you can 'repair' it a menu.  This didnt work on the drone sadly - file 154 still wont play.  Muchas gracias anyway.
2020-8-13
JasonWilli
India
The DJI videos may get corrupt due to several reasons. No matter what would be the reason for video file corruption, your primary concern is to repair and get your files back in a fine condition. This post mentioned some effective methods to repair corrupt DJI video files. Find Out More Information : https://dronephotographybible.co ... pt-dji-video-files/
2020-8-28
Electromen
Flight distance : 275531 ft
Can you post the file or a link.  Do not compress it.  Compressing  a compressed file is not a good idea.
2020-8-28
