No Betaflight OSD
3874 7 2020-8-22
TBer
Hi, I can't get the Betaflight OSD to show in the goggles.
Latest DJI firmware, using Ixing SucceX-D F7 V2.1 flight controller.
I have tried a different controller and it wasn't working either, although I have a Matek F765 controller with iNav and OSD was showing with that.
I have tried pretty much everything...
2020-8-22
VanPit
Poland
There is an option in goggles menu named sth like  "Custom OSD". Did you turn it on?
2020-8-23
VanPit
Poland
There is an option in goggles menu named sth like  "Custom OSD". Did you turn it on? See this thread https://forum.dji.com/thread-203712-1-1.html. Also check Your config of BF with wiring diagram on iflight page https://shop.iflight-rc.com/index.php?route=product/product&product_id=1043 I have SucceX-D F7 + betaflight configured with that instructions and everything works.
2020-8-23
TBer
VanPit Posted at 8-23 05:40
Yes, it's turned on and the Flight controller should be plug & play with DJI, so MSP for Uart 2 was already on.
2020-8-23
VanPit
Poland
In my case when I receiver this FC first thing was to upload newest betaflight and reset all settings. Thn BF configurator sugested to put some default config on FC. Maybe try that. Also please check if your googles display red "Unlocked" message on the right side when arming the quad. If not - maybe UART cable (FC <-> DJI AU) is fauly?
2020-8-23
TBer
There is something wrong with the air unit. I have 2 and with the other one OSD is working fine both with Betaflight and iNav. on 2 different flight controllers.
2020-8-23
djiuser_napzpxgeIe4q
I just setup mine and I see all the info on the osd needed to fly but when I try to access the beta flight configuration on the osd it doesn’t come up.
2021-8-7
babang
Flight distance : 2439117 ft
Norway
Hi, same problem here, I can't get the Betaflight OSD to show in the goggles.
Latest DJI firmware V01.00.0606 I'm using mamba f405dji flight controller. the UART is 2
I have tried 3 different fly controller from different quads but still no osd. the same fly controller  give me OSD from the other air unit.
please HELP
2021-8-22
