DJI FPV Goggles AV-in issue
5250 14 2020-8-25
DavidFpv
Israel
Peace,
I connected today to my RX 5.8.
I see well but having weak reception reflecting replaces the image on a black screen with the DJI logo and then returns to the weak image.
Does this happen to anyone?
rx: https://www.racedayquads.com/products/foxeer-wildfire-5-8ghz-diversity-fpv-goggle-receiver-module-choose-your-color?_pos=1089&_sid=f2ded412f&_ss=r
analog adapter: https://www.racedayquads.com/products/analog-fpv-fatshark-module-adapter-for-dji-digital-fpv-goggles?_pos=1266&_sid=f2ded412f&_ss=r
2020-8-25
KREMi
Poland
no - I got different setup (URUAV adapter + pro58 RX) but when drone is loosing video link, then it goes full snow  but won't jump to DJI logo. when signal is again stronger snow will be going away.  (just did a test @ home)
Maybe setting in your RX or this adapter, kills AV when signal is low to save battery or somth?
2020-8-26
DavidFpv
Israel
KREMi Posted at 8-26 09:27
I tried using rapidfira and got the same thing
Can you please tell me what settings I can try to change?
2020-8-26
KREMi
Poland
DavidFpv Posted at 8-26 10:50
according to Your explanation - something is cuting off AV feed when it have lost videosignal from drone
My googles are not switching back, so lets say googles are ok.
then only Adapter or RX can cause it. If You say other module (rapidfire) is doing same blackouts, I think that chance for 2 different RX modules being faulty in same way is pretty low.
so sherlock time ;) if googles are ok, then only this adapter can cause problems
2020-8-26
DavidFpv
Israel
KREMi Posted at 8-26 18:57
I think it happens because the video is weak and the DJI FPV disconnects from this video and then he sees that there is something there so he comes back ...
I'm no longer an adapter but I'll ask one of the groups if anyone can check out the problem
And this is what it looks like ...
2020-8-26
KREMi
Poland
DavidFpv Posted at 8-26 21:24
no link or anything under "this is how it looks like..."
my set of adapter and RX let me even disconect battery from drone = no signal at all yet googles stilll stay in av-in mode.,(a classic tv static noise = snow screen).
when I reconnect battery - I got image from camera returning without any delay
2020-8-27
DavidFpv
Israel
KREMi Posted at 8-27 03:07
Yes but in my case when I disconnect the battery I get snow screen!!!
I get the logo screen when my signal is very low...
I am going now to my friend, he has set up of dji fpv and analog rx
2020-8-27
KREMi
Poland
DavidFpv Posted at 8-27 04:35
and? did You found out what it was?
2020-8-28
DavidFpv
Israel
KREMi Posted at 8-28 10:52
Not yet because in the end I did not have the opportunity to meet my friend ... Can you maybe try and see if that happens to you? In really really weak absorption your mirror resets?
2020-8-29
Bezik
Flight distance : 420646 ft
which firmware are you running on your goggles? im sure id read somewhere that the problem of going back to the dji logo on low signal was fixed in a firmware update
2020-8-29
DavidFpv
Israel
Bezik Posted at 8-29 06:50
When I opened the forum I was in one version before the last and now I am in the latest version but the same without change in distance even with the 2 shelters
2020-8-29
djiuser_MakpNjtAykTP
I have the same Issue. According to the DJI assistant I'm on the newest firmware. And i have a very similar setup as the original poster. I'm running a Wildfire too. But i confirmend this issue with another AV source (EV100)
2021-3-4
HirschBoy
I found a solution for the problem had to refresh the firmware on the DJI goggles and restore the factory settings now it works fine
2021-3-4
djiuser_xB3lEij6Iq7W
DavidFpv Posted at 2020-8-29 01:09
I have the same problem i have rapidfire and and my quad is brand new
2022-5-8
ro_flyer
Flight distance : 7557283 ft
Brazil
great views!
2022-5-12
