mavic air 2- how to use new zoom feature?
27180 12 2020-8-26
Rmoore7167
I see that with the new  version update that V01.00.0340 provides a zoom feature for the Mavic Air 2. I cant seem to figure out where it is.  Ive tried different settings.  Any suggestions on location and how to use?
2020-8-26
George210477
Flight distance : 2866296 ft
Romania
Keep the FN pressed and use the gimbal dial for smooth Zoom.
For raw Zoom, you have in Right a 1x to be clicked.
You need to select at Video: 4k Zoomed = max 2x or 1080p=max 4x.
Cheers.
2020-8-26
Rmoore7167
Thanks.  I have tried that and it doesn't work.   I installed new update 01.00.0340   I did have a power issue when installing ...could that be issue?
2020-8-27
George210477
Romania
Connect to PC with DJi soft, click REFRESH on firmware... Will be rewritten.
Be carefull... I have tested the digital Zoom, în 4k is medium noise, în FHD is a lot of noise... As semi-pro you cannot use it... For hobby it will work ok.
2020-9-12
A J
Flight distance : 15283773 ft
Rmoore7167 Posted at 8-27 06:53
Make sure the version of the fly applies also updated to at least 1.1.6
2020-9-13
Terry777
Flight distance : 314006 ft
A J Posted at 9-13 02:44
Cool, i didn't know about that. It looks like decent flying weather tomorrow so i'll get out and try it out!
2020-9-13
A J
Terry777 Posted at 9-13 16:28
It was updated with the last firmware in early August. However, version 1.1.8 has just been released so update to that
2020-9-14
djiuser_tU7Y5DXyrTfS
George210477 Posted at 2020-8-26 21:42
I was wondering this myself thank you
2021-6-1
Darin777
Flight distance : 22398 ft
I just updated this morning and have no zoom function at all. I’ve checked and rechecked as well as checked to make certain my firmware is up to date.  What am I missing??
2021-6-4
Darin777
Darin777 Posted at 6-4 03:50
When I try to update the firmware it states “ up to date”
2021-6-4
djiuser_GBVaHQtHSuTi
Belgium
Might be a bit late but I have the same problem. I contacted the online support. Turns out that my iphone 5 does not support the zoom function within the flying app....
2021-6-18
djiuser_1pfHAhhpNrwl
Darin777 Posted at 6-4 03:56
I am having the exact same problem. Did you find a fix? I had a mavic air 2 that was overheating. I sent it back and they sent me a replacement through the care refresh program. Now this one does not overheat but will not update at all I get the exact same screen as yours. I was able to update the controller and the batteries but not the drone itself. I tried everything discussed here to no avail. This is very frustrating, this is the second air 2 and I keep having problems.
2021-7-20
odesius
Rmoore7167 Posted at 2020-8-27 06:53
You need to set video to 1080p 30fps I did this with litchi in fly app there’s normal hdr and another but I can’t see how you do 1080p
2022-10-18
