DJI FPV Controller not connecting to DJI Assistant 2
5789 8 2020-8-29
Joshua Huskins
Flight distance : 256893 ft
I recently purchased a used FPV controller and I was trying to upgrade the firmware. When I connect it to my mac and have the controller turned on, the assistant does not recognize the device. Controller is fully charged. Left most LED is solid red. Any help is greatly appreciated.
2020-8-29
Bezik
Flight distance : 420646 ft
might be a silly question but always a good place to start, is it the specific assistant 2 for the FPV system?
https://www.dji.com/uk/downloads ... nt-2-dji-fpv-series
2020-8-30
Joshua Huskins
Bezik Posted at 8-30 06:03
https://www.dji.com/uk/downloads/softwares/dji-assistant-2-dji-fpv-series
Ugh, had no idea there was two versions. Assumed the one I had was all inclusive.  Thanks Bezik!
2020-8-30
Bezik
Joshua Huskins Posted at 8-30 06:07
yeah its an odd system but different assistant for each series, ive seen it catch a lot of people out
2020-8-30
mochacha
Flight distance : 100876 ft
United Arab Emirates
Bezik Posted at 2020-8-30 06:19
2021-3-18
fans4a6944db
Flight distance : 337776 ft
updated controller on dji assistant 2 FPV, updated goggles, but drone just wont show in the app, and i am not able to verify that the 2 batteries from the dji fly more kit actually can be updated, since they will not let me take off. Please help !!!! Thank you
2022-5-9
ro_flyer
Flight distance : 7557283 ft
Brazil
great views!
2022-5-12
fans16167a2a
Same issue here.     Are we supposed to use the FPV or Consumer assistant ?      Avata connected fine in Consumer version    FPV Remote 2 will not connect to either.    Is there an order to connection ?     Eg : Open software , plug in USB to device , power on device , wait for device to appear ………………..help !
2022-9-20
Joshua Huskins
fans16167a2a Posted at 9-20 04:40
The Avata uses DJI Assistant 2 (FPV Series), not consumer. You should be able to connect once you use that version of the app. If you are running on a Mac then there is potentially a different problem you are seeing.
2022-9-20
