Re-balance required on pan axis when balanced
591 3 2020-9-3
berlindx
I have tried over and over to get the pan axis to pass the balance test. Roll and tilt are excellent. The pan axis doesn't rotate when I tilt the  gimbal. It is definitely balanced but I keep getting the same result. Any ideas?
App version Android 1.2.10
Firmware 1.5.0.40. Same thing happened on the firmware that came with it before I updated. Not sure what it was.
IMU 0.5
GCU 1.1
Sony A7III with a Tamron 17-28mm F/2.8
Thanks!
2020-9-3
M2Wair
Flight distance : 1192231 ft
Same issue, multiple cameras and lenses
2020-9-5
DJI Susan
Hi there, please make sure that the Ronin SC is physically balanced properly, if the gimbal stays still when it is tilted left and right 15° when it is powered off, you can ignore this message. Thank you.
2020-9-8
M2Wair
DJI Susan Posted at 9-8 20:35
Not the first gimbal, nor a novice at using Ronin
Prpducts I already have a Ronin S and another Ronin SC have this issue on a new ronin SC. No issues with first 2 gimbals the third gimbal has the issue
2020-9-15
