arives
Flight distance : 453684 ft
I have the Tab 4 and they play fine on mine. I was flustered in the beginning as I couldn't play them either, until I learned the trick in the User Center. The videos transfer there from the Copter and you need to tap each one and have the app set the videos up so they are playable. You will see a little white circle show up, be patient, it will begin to show that the app is doing something to the file, to make it playable. After that they should be playable, and you will have to do that to each of them.
If you already have done all that, sorry I bothered you. I have no other suggestions. |
