cookinghusband
Flight distance : 41463 ft
What I mean is when you are using the remote to pan/tilt the ronin-m it is more or less the best it can do in smoothness terms ( for the setting U have use). if you find the smoothness ok using remote, then it must be how you are holding or moving around which is the problem for the jitters.
you still need to use the gimbal like using a glide cam for best results. |
