MapView not focus
482 3 2020-9-12
djiuser_0wZiRVZwQQOj
Flight distance : 131860 ft
Israel
Hello ,
I build app from DUXDefaultLayoutViewController, this is connected to the drone.
The mapView widget not focus on user location, there is an example how to do that progratcally ?
Thanks Yakir.
2020-9-12
JohanH
Flight distance : 30479 ft
The following will keep the map centered to the drone:
mapWidget.isMapCameraLockedOnAircraft = YES;
The following will keep the map centered to the homepoint:
mapWidget.isMapCameraLockedOnHomePoint = YES;
You can use the above in viewDidLoad of the DefaultLayoutController
The following will show user location (that is location of the mobile device which is only accurate if it has GPS enabled) :
mapWidget.mapView.showsUserLocation = YES;
The following you can use in viewDidAppear of the DefaultLayoutController to center the map to the user location:
[mapWidget.mapView setCenterCoordinate: mapWidget.mapView.userLocation.location.coordinate];
I hope this helps!
2020-9-12
Israel
Thanks i’ll try and keep you update.
Another question-the active track is just one of the option and this is will work on the mavic mini , or i need to add some code for this ?
Regards Yakir
2020-9-12
Israel
JohanH Posted at 9-12 05:21
Regards Yakir
2020-9-12
