Does MM uphill flying without RC up input?
813 17 2020-9-14
JJB*
Flight distance : 12477300 ft
Hiya,
Did a test with my MM.
How does it perform when flying forward (only fwd stick, zero up-stick all the time) while the ground below is becoming a slope...
Flying forward really slow my MM adjusted its height above the ground, see the video.
But flying bit faster....it did not steer up quickly enough to keep the same distance drone>ground.
IMO VPS height signal at 0.5 meter is used for the automatic landing ; hover at 0.5 meter, push 100% down stick for short moment, MM will autoland in a slow controlled rate of descend. Happy landing. If you hover 30 meters height in sport mode, apply 100% stick down all the time ; you will see that within VPS height range rate of descend will slow down and at 0.5 meter drone will hover steady, after that it will enter autolanding if still 100% down is applied.
Flying fast forward too low and getting lower, MM will not counter that descend and fly into the ground.
Looking forward to see video`s wich shows me being wrong   ;-)
cheers
JJB
2020-9-14
A J
Flight distance : 14312858 ft
Cool video
2020-9-14
virtual
Flight distance : 4897142 ft
Czechia
TBH I would guess this behaviour. If You put your hand under the Mini the sensor doesn't respond very quickly and field of view is not wide as well...
2020-9-15
JJB*
virtual Posted at 9-15 01:12
just make a video.... ;-)
With no descend  and forward speed in  hover indeed  'hand under mini' nice response
IMO with vertical speed down it will not fix too much speed down.
cheers
JJB
2020-9-15
Woe
Flight distance : 4129268 ft
Cool video.
2020-9-15
Ralle
Flight distance : 11289 ft
Finland
2020-9-15
Ralle
Finland
Cool video!!!!!
2020-9-15
AMIR_king
Flight distance : 372992 ft
Nice Test!!
2020-9-15
virtual
Czechia
JJB* Posted at 9-15 02:20
I haven't experiment that much but results were similar to yours. When I went over the rooftop it doesn't work like OA, so I would be affraid of crash flying slope or any tilted obstacle...
2020-9-15
Suren
Flight distance : 13498560 ft
New Zealand
Nice test JJB, Dji need testers like you on the field that will test all these functions then we won't see posts about newbies making silly bugger mistakes
2020-9-15
AMIR_king
Suren Posted at 9-15 10:46
Exactly!
2020-9-15
djiuser_YOZoFpdlWBla
Flight distance : 42415 ft
I tried it today and it dose work on a gradual incline but you have to be careful and don’t go to fast.
Second try it went into the grass and I think was going to fast.
Doug
2020-9-15
JJB*
djiuser_YOZoFpdlWBla Posted at 9-15 20:35
Doug
Hi Doug,  nice to see more people testing and showing their results.
and yes, exactly my experience, flyingreal slow it does work.
cheers
JJB
2020-9-15
AMIR_king
I tried last night, worked better than I expected!
2020-9-16
JJB*
AMIR_king Posted at 9-16 05:40
Great,  this is how to learn all the facets of your drone, testing and testing.
Ever tried to hover at 30 meter height, sport mode and full stick down all the way down?
(leave 100% down stick until it has landed)
cheers
JJB
2020-9-16
AMIR_king
No can try tomorrow at the park!
2020-9-16
AMIR_king
Thanks for the idea!
2020-9-16
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for creating this informative post. This will be a great help to our valued DJI co pilots who owns a DJI Mavic Mini. Great work and thank you for your value support.
2020-9-16
