How many cycles of battery is considered a good one?
6045 9 2020-9-15
allyssongemelli
Flight distance : 2003783 ft
Brazil
Hello guys! I have two batteries, maybe 75 cycles each one. I try to storage correctly after a fly, not charging them hot. The battery can be a lottery, but how many cycles you can consider that is a good battery? 150, 200 cycles?
See you soon.
2020-9-15
JetSam
Flight distance : 2818264 ft
I have my original that came with my Phantom 3 SE WITH 150 cycles , util life is 35 % or less  , but i did not use it anymore , by precaution
2020-9-15
allyssongemelli
Brazil
Cool. Yeah, it's a good idea always check the cells voltage, if they are balanced, or even a little difference 0.01V. And storage at a good place.
2020-9-15
JetSam
Mine is totally balanced after 150 cycles but voltage is not reliable IMO
2020-9-15
allyssongemelli
Brazil
JetSam Posted at 9-15 09:53
Yeah, the autonomy is not the same as a new one. The same 100% battery charged will have deliver less minutes of flight.
2020-9-15
DJI Stephen
Super Moderator
Hello and good day allyssongemelli. Thank you for reaching out and for the inquiry. The charge circle is 300 times under normal circumstances and 200 times under 40-degree centigrade. The battery can still be used if the charge cycle is more than 200 times. The battery's warranty period is 6 months and the Charge Cycle less than 200 times. Actually, the battery life span of your unit, regardless if it's the intelligent flight battery would depend on how you will take care of it. In addition I will post a link where in you can fine the DJI Intelligent Flight Battery Safety Guidelines ( https://dl.djicdn.com/downloads/ ... y+Guidelines+En.pdf ). Thank you and fly safe always.
2020-9-15
allyssongemelli
Brazil
DJI Stephen Posted at 9-15 20:01
Hello and good day allyssongemelli. Thank you for reaching out and for the inquiry. The charge circle is 300 times under normal circumstances and 200 times under 40-degree centigrade. The battery can still be used if the charge cycle is more than 200 times. The battery's warranty period is 6 months and the Charge Cycle less than 200 times. Actually, the battery life span of your unit, regardless if it's the intelligent flight battery would depend on how you will take care of it. In addition I will post a link where in you can fine the DJI Intelligent Flight Battery Safety Guidelines ( https://dl.djicdn.com/downloads/phantom_4_pro/20170125/flight+battery+safety+guidelines/Phantom+4+Series+Intelligent+Flight+Battery+Safety+Guidelines+En.pdf ). Thank you and fly safe always.
Cool DJI Stephen, thanks for reply. Good to know, a great reach is 200 cycles. Thanks
2020-9-16
DJI Stephen
Super Moderator
Hi there allyssongemelli.  You are very much welcome and thank you for the reply. If you have any other concerns or inquiries with DJI. Please feel free to post it here at DJI Forum. We are all here to help and support you. Have a safe and a happy flying always.
2020-9-17
JetSam
DJI Stephen Hello , i used the original battery of my Phantom 3 SE about 155 times , util life is about 40%, do you really think this is reliable to use it ?
PD : cells are totally balanced
2020-9-18
fans8f5433e3
DJI Stephen Posted at 2020-9-15 20:01
Hi.  I’m confused by your answer.  You say “Normal is 300 charge cycles”.  “But if the temperature is under 40c (104F) then you only get 200 cycles”. That doesn’t make sense to me.    What is the “normal” temp so that I can get 300 charge cycles?
2022-7-22
