Communication Issues
769 4 2020-9-18
jpborray
Flight distance : 19400 ft
Mexico
I have had a spark drone (MM1A) for about 3 years and recently I have experimented communication issues when the drone is on flight, it appears on my screen that the communication was lost and can´t see anything and control it, actually, once I had to wait until the drone returned to the takeoff place because it was impossible to restore the communication. I´d like to know if there is any solution to these problems, let´s say I´m experience them one year ago.
2020-9-18
Wolferl
Flight distance : 23793 ft
Hi,
We need more information....
- where were you flying when the problem occurred?
- are you using the remote controller or your phone to control the Spark?
- what phone are you using (may be another phone used since your Spark was new)
- what versions (Spark and R/C) do you have?
- when you used the R/C: are you using an OTG cable also?
Cheers,
Wolferl
2020-9-19
jpborray
Mexico
Wolferl Posted at 9-19 04:37
Hi,
here it is,
I was flying on a natural park close to Mexico City called "La Marquesa", I was using remote control to control it (I always do), I use an Iphone X (no changes), versions: app 4.3.3.38, spark 01.00.1000, RC 01.00.0600, no cables when flying.
Tks!
2020-9-19
DJI Stephen
Hello there jpborray. I am sorry to read and to know what that you are having this issue with your DJI Spark and thank you for reaching out. Can you please fly your DJI Spark to a different location to see if the issue will still persist? The said DJI drone might have picked up magnetic interference from the area. That might be the reason why you are experiencing these issues. In addition, I will post an official DJI tutorial video on DJI Remote Controller Antenna Best Practices. Thank you.
2020-9-20
dji_MODDER
Flight distance : 73209 ft
Change you wifi channel to 2.4 ghz for outside community in open field for better range, switch to 5.8 ghz to in area's with lot of wifi's.
When switched use an otg cable for best communication between RC and Phone.
Switch off your bluetooth, and when you use OTG cable the wifi on your phone.
2020-9-21
