Mavic Air 2 stuck in "startup" mode.
2430 15 2020-9-27
Pardalouco
Flight distance : 626339 ft
Hi there!
Bought an MA2 less than a month ago. Did 2 short flights. Had the drone stored for a week and now when I try to turn it on it does not go out of the start-up mode (rear lights flashing red, yellow and green). It does not recognize the RC. When I try to connect it to the PC it boots, but then if it is like I unplugged the USB cable... and it keeps on doing this... tried different cables.
Any ideas besides sending the drone back and most likely ask for my money back?
2020-9-27
DJI Stephen
Hello there Pardalouco. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try to refresh the firmware of your DJI Mavic Air 2 to see if the issue will still persist and can you also please post a sample video of the said issue for us to see and assist you further? Thank you.
2020-9-27
Pardalouco
DJI Stephen Posted at 9-27 22:59
Thank you for the reply.
How can I refresh the firmware if the drone "does not see" the RC and when I plug to the PC via USB it keeps on "plugging/unplugging" on its own? It is an unbelievable design flaw not to have a "factory reset" on the drone itself.
I will do a video of what's going on. Thank you again.
2020-9-28
lannes
Flight distance : 4465 ft
Pardalouco Posted at 9-28 02:04
Have you installed the right version of DJI Assistant 2
https://dl.djicdn.com/downloads/ ... or+Mavic+2.0.14.exe
Try re-running the driver installation, you can see the file path at the top of the image below.
Pick the one for your windows version 32bit or 64bit
2020-9-28
Pardalouco
lannes Posted at 9-28 02:25
[Image]
Did it already, and yes, is the correct version. The drone is stuck in "start up" mode and i can't access it to refresh the firmware... less than a month of use... what a crap.
2020-9-28
lannes
Pardalouco Posted at 9-28 04:27
Have you tried do a firmware upgrade from within DJI Fly ?
Otherwise it's  probably "bricked" , best return it to DJI for repair
2020-9-28
frankymusik
Flight distance : 27841053 ft
... sometimes it takes me longer for the DJI Assistant 2 to recognize the connection to the MA2 ...
It may also help to remove and reinstall this assistant ...
2020-9-29
Pardalouco
lannes Posted at 9-28 18:26
Like I said, when I connect the drone to the PC via USB it connects and disconnects on its own and so I can't refresh the firmware.
I guess it is bricked... my only doubt is if just should ask for my money back or to repair... it is still inside the "one month period" that the store has to honour in case of a malfunction.
I'm scared with all the people complaining about similar issues.
Thank you for your reply, by the way.
2020-9-29
Pardalouco
frankymusik Posted at 9-29 12:53
I did it 69 times... I guess I will try it once more before I return it to the store. An issue like this when the drone has only a month and did only 700 feet of flying... for me is enough,
2020-9-29
Scott108
Flight distance : 314419 ft
This is a longshot, but I didn't see it mentioned....  Have you tried a different battery?
2020-9-29
Pardalouco
Scott108 Posted at 9-29 14:04
Yup... all 3 of them... and nothing!
2020-9-29
Tentoes
Flight distance : 6018255 ft
Very strange.
You turn it on by pressing the button, then pressing and holding. Does the gimbal look all around and up and down?
(Face it, I'm probably not going to figure it out here.)
2020-9-29
Pardalouco
Tentoes Posted at 9-29 16:40
Very strange.
I think so...
2020-9-29
Taha Rasheed
Tanzania
Hello, im having the same issue has anyone rectified yet?
2022-1-11
Sean-bumble-bee
Flight distance : 15997 ft
try removing the mSD card from the drone. A corrupt or perhaps unwelcome file on it can screw up the drone's boot. I had this happen with a Mavic 2 Pro or Zoom.
2022-1-11
djiuser_EG49aLKuWNVs
Well; how did it end?
2022-12-20
