A J
Flight distance : 13978875 ft
GaryDoug Posted at 10-2 13:38
You said this in post 24: "4 pairs equals 8 props"
Then you said to always replace the whole set of 4 pairs.
Then : "And if you only have one damaged prop then why do DJI only sell them in pairs?"
Yes, if you bothered to read the thread you will clearly see that I was replying to kiminx regarding his post number 23 where he incorrectly stated that he "only changed one damaged prop and not all 4 pairs"... Point being that the drone has 2 pairs doesn't it. To which he replied in post 28 "well noted".
Then I advised that "Quadcopters have 4 props = 2 pairs" and that "I always replace props in sets to prevent the chance of vibrations showing in the image" Again, I have never stated to replace all 4 PAIRS - please show me exactly where that is stated...
Then my reply to YOU "and if you only have one damaged prop then why do DJI only sell them in pairs?" was clearly in relation to your reply in post 19 where you stated "If DJI recommended replacing 4, wouldn't they come in packs of 4 instead of two? Point being, that the number of props that DJI sell in a box is not reflective of the number of props that need to be replaced in the event that one may be damaged.
My opinion, as noted in post 9, is that I would change all 4. You may also wish to refer to posts 29, 28 and 26 to see why. To which the OP thanked me.
If you believe keeping a prop on your drone that has been flown for hundreds of miles and many hours is safer than replacing it with the brand new ones DJI supplied with your drone (amongst the ones you are already using of course) then good luck!
So the obvious conclusion - I do not care how many props DJI sell in a box. But if I have flown my drone for many hours and suddenly damage one or more props I will replace all 4 props at the same time. Oh, and for you to actually read threads more thoroughly in future to prevent taking peoples replies out of context...
