Mavic Air 2 Calibration Error
2919 7 2020-10-2
Pabsman
Flight distance : 367 ft
Bolivia
So I tried to do a Sensor calibration on my laptop and I got this error.
Calculation Error. Recalibrate now. 2-2 eul_x(-6.21-0.005-0.00).
I tried calibrating wiith a 14 in screen 1360x768 resolution.
Can someone help me with this?
Thanks.
2020-10-2
Suren
Flight distance : 12803399 ft
New Zealand
When I did mine I connected the laptop to my TV and it worked. was having issues with laptop screen
2020-10-2
Pabsman
Bolivia
Suren Posted at 10-2 11:17
I tried connecting it with an HDMI cable but I got a size screen error.
2020-10-2
Suren
New Zealand
Pabsman Posted at 10-2 12:25
Not sure then
2020-10-3
kiminx
Flight distance : 125430 ft
2 times i calibrated and ok. Using 14" notebook screen. Just direct your ma2 sensor camera and move follow the squarel.
2020-10-3
frankymusik
Flight distance : 27262490 ft
You have to pay close attention to the displayed boundaries (corners) and do it very carefully.
"Hold" the MA2 nicely in the middle in front of the screen and carry out the movements for following the displayed area on the screen only by slightly "tilting" the MA2 ...
At first I didn't have any success ...
... but "practice makes perfect".
2020-10-3
Vendex
Flight distance : 15994042 ft
Bulgaria
Hello, Mavic Air 2 now using auto calibration, no need for manual. Do it manual only if auto calibration fails.
2020-10-3
DJI Stephen
Super Moderator
Hello there Pabsman. I am sorry to know that you are having issues with the sensors of your DJI Mavic Air 2 and thank you for reaching out. Please try to calibrate the said drone using a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.) . Thank you.
2020-10-4
