Firmware v01.00.0670 - How happy are you with it?
2265 8 2020-10-2
xagoras
Flight distance : 1357589 ft
Greece
Hi guys. Firmware v01.00.0670 has been released for 3 months now, but I'm still reluctant to install it, mainly because of the reports with various problems arising after the update. Problems like connection between RC and AC, weaker signal etc. Of course the reports could only reflect a tiny fragment of the Mavics out there.
So if you could take a minute and vote, would be great to get a better idea on where we really stand with the latest firmware and if it's worth it.
Thanks in advance.
Single SelectVote, Total 30 people participate in voting
Your user group with no voting privileges
2020-10-2
gnirtS
Flight distance : 5712575 ft
Works exactly the same as all the other firmware releases.
2020-10-2
Suren
Flight distance : 13438648 ft
New Zealand
Works as advertised with no issues so far to my drone.
2020-10-3
JohnDG
Flight distance : 1097270 ft
Belgium
I am on the latest firmware updates for the M2P and smart controller, no problems at all.
Just be aware that firmware is the base control software of your devices. I experienced that using wifi to update is not a good way. Use the DJI Assistent software on your pc or mac to update drone as well as your controller. Some drone updates require updates of the controller and/or battery firmware.
Problems with connecting USB often can be the problem of the usb hardware of your computer or it's driver. It's not always the DJI product that is causing the problem.
Keep your controller alive while it is updating. Prolong the sleep time or tap from time to time on the SC screen to keep it alive.
Check on your battery power before starting an update. You don't want to fall out of power in the middle of an update.
Sometimes adding some extra software on the SC can cause interference with the update. If you experience problems, do a factory reset.
Keeping those in mind I had no or less problems updating firmware. Since I'm using drones from DJI I updated drones and controllers regulary. DJI has given no more or less problems than any other device I upgraded firmware of.
2020-10-3
Lucas775
Flight distance : 50642090 ft
Works as promised.  I flew my M2pro this morning and that thing is stable like you wouldn't believe.
2020-10-4
DJI Stephen
Hello there xagoras. Thank you for reaching out and for creating this poll. I hope that our fellow DJI co pilots can give out there valued insights with regards to this matter. Thank you for your support and please stay safe always.
2020-10-4
STST
Flight distance : 734882 ft
Israel
The Firmware v01.00.0670 Killed my Mainboard ,
Transmitter  disconnections after short distance of a few meters,
The adventure cost me 410$  -  Mainboard Replacement.
after the replacement with the last firmware v01.00.0670
the drone work,
the original mainboard manufacturing date 2018.6
the replacement mainboard manufacturing date 2019.6
Maybe the firmware only kills old mainboard.
2020-10-6
bjr981s
Flight distance : 139698 ft
Had no issues to date. I use the SCs for my Pro and Zoom.
2020-10-19
slo007
Flight distance : 41030 ft
In my case, the firmware upgrade took ages to complete. It crashed numerous times whilst trying on the Samsung S7 and didn't even bother to come up on the iPad Pro; which was quite a mystery. Finally, it completed fine on the S7 at the "10th/last" try (the drone refused to fly meanwhile). Thereafter, I noticed the drone hooks up to satellites much faster for GPS flight - although I didn't mind waiting before.
However, things went crazy yesterday when I came in for a landing and the sensors completely failed to detect the ground and the drone did a "controlled" belly landing on the sand (previously, it would have come to a halt near me or the ground). Fortunately, nothing broken.
I always record the pilot's view and video footage confirms sensors were on. It appears they only realised where the drone was too late. "Landing!" it says, after touching the ground. Will post a link shortly.
2020-10-19
