Same place, one with good signal, one with bad signal
964 5 2020-10-5
fans91324663
I have two air units.
One in a wing. The other one in a quad.
I get a much better reception with the quad. See attached image.
The settings on both:
- High quality
- Focus Auto
- Bitrate 50 mbps
My two units are registered with DJI Assistant 2 (FPV).
On both I did the following steps:
- sd card in air unit with naco.txt (1 in the file)
- power on goggles
- power on air unit
Why is the reception different ? I feel that with the wing, I cannot go very far.
Also, when I look at the Player menu, I only see 3 channels (ch1, ch2 and the public ch8). I don't see ch3.
I'm located in Canada.
I've tried ch1 and ch 2 on both. Same result ... better reception on the quad.
Thanks.
2020-10-5
Kreeze
try switching the air units and see if it follows the air unit or the aircraft
2020-10-5
Giammi
Flight distance : 847795 ft
Try switching them and see what happens. Then let us know.
2020-10-5
fans91324663
Giammi Posted at 10-5 22:35
I'll try two new antennas on the wing first.
Then yes, good idea, I'll switch the air units and see how it goes.
2020-10-6
mc54
Flight distance : 1030 ft
I've found the antenna connections on the air unit are a weak point that constantly need checking.
2020-10-6
fans91324663
I found the solution to my problem.
When the air unit is not connected to a FC like in my wing, you have to turn OFF the Auto Temp Control.
If you don't do that, the unit with stay at 25mw.
2020-10-14
