ATTENTION! Smart Controller doesn't stay linked (paired?) with M2Pro
4259 16 2020-10-7
SDsc0rch
Flight distance : 823028 ft
i've had to re-link (pair?) over and over again
i start up the drone and i am prompted to select my drone and press the link button on the drone
over and over again
probably over a couple dozen times over the last couple days
i use my drone to earn my living
i just updated to the latest firmware last weekend (early october)i'm curious if anybody else has seen this??
we're gonna need a hotfix for this because its a major pain in the tail....  : /
2020-10-7
Visual Air
Flight distance : 2710115 ft
Go to settings and aircraft management select the drone there. You should not have to re pair.
2020-10-7
JohnDG
Flight distance : 1097270 ft
Belgium
hi SDsc0rch,
I got my drone profile in aircraft managment like Visual Air mentioned in 2#.  Am using the latest firmware for the M2P as well on the SC. I didn't have the connection problem you experiencing.
2020-10-8
InvisibleName 7
Flight distance : 795653 ft
Nope, no “hot fix” needed here - latest firmware works perfectly
2020-10-8
SDsc0rch
nope ---- this is the fourth day in a row
EVERY. SINGLE. TIME. i restart the SC, i have to re-pair with the M2Pro
YES --- we need a hotfix
this latest firmware broke the pairing/linking
this is totally repeatable and reproducible
want me to post a youtube??
cuz i will !!
2020-10-8
Visual Air
SDsc0rch Posted at 10-8 16:26
When you first power on your Smart Controller bottom left of the screen the box that States connect. Is that how you are selecting the quad?
2020-10-8
SDsc0rch
negative ---- when i turn it on, there's the "connect" screen - when you click "connect" you see a dark screen where you select the model of drone you have
i click M2Pro and it starts beeping - it beeps until you click the pair button on the drone (starboard side - pull open the access panel)
once clicked, the nickname i gave the drone appears and you proceed normally
happens EVERY TIME the smart controller is powered off
2020-10-8
InvisibleName 7
Have you gone into settings / aircraft management and set it to your specific model?
2020-10-8
Luca85
Flight distance : 1257628 ft
Hi, I had upgraded my smart controller to the latest version, but I was having problems with signal loss at a short distance. I downgraded to the previous stable version with dji assistant 2, now it works fine for me and the mavic 2 zoom. Good luck
Luca
2020-10-9
JohnDG
Belgium
Try to reinstall the latest firmware using a pc and the DJI Assistent 2 program.
https://www.dji.com/be/downloads ... ant-dji-2-for-mavic
also save your settings, afer reconnecting to your drone, in the settings / aircraft (make a profile) like InvisibleName7 suggested in 8#
Most of us don't experience your problem, so it is specific to your system, not a general fault. If those steps above don't help, I suggest you contact DJI support about it.
2020-10-9
Visual Air
SDsc0rch Posted at 10-8 18:47
Yes you have to go into settings and then aircraft management and select the drone there. then you do not have to re pair.
2020-10-10
TomAir9
Flight distance : 314144 ft
Don't click on the Connect button.  Just go to Apps screen and run DJI Fly.  Worked for me.
2020-10-10
SDsc0rch
Visual Air Posted at 10-10 07:08
okay.... i will try this
thank you for your response
2020-10-11
SDsc0rch
TomAir9 Posted at 10-10 09:21
i will try this also if the method described in the next post doesn't work
thx for pitching in here
2020-10-11
SDsc0rch
SDsc0rch Posted at 10-11 12:37
THIS!
this worked!!
i just turned the drone and SC off then on - good
then left the drone on and cycled the SC - good
then repeated just to make sure i wasn't just getting lucky ----- goodgood
many thanks!!  : )
2020-10-11
Iman_Oldie
Flight distance : 125 ft
I'm glad I found this post.
I recently bought the Mini 2 Smart controller Combo and was having the same issue with my Mini 2 and Mavic 2 Zoom.
All good now but it makes you wonder why DJI didn't make this clear. Their own directions on the controller say nothing about going into Settings to select your drone.
I also often get a warning saying the drone does not support DJI Go 4 and I haven't selected an app.
2021-9-8
JTrem
Flight distance : 328589 ft
I was having the same issue. Now it's fixed thanks to the tips above.
2021-10-8
