SHANE153
DJI Natalia Posted at 10-13 04:23
Hi Leke, please start the Smart Controller, find "settings--aircraft management" to reselect the aircraft, then restart the controller to try the connection again. If the issue still persists, you are recommended to contact our support team via http://www.dji.com/support to open a case and send it in for service. Thanks.
Hi Natalie,
i am encountered the exact same fault as Leke, i was flying fine, then the drone disconnected mid flight, came home, and i have not been able to reconnect my SC to the drone again, i am getting the same message after doing the update, i have also found some times the syn or connect button on the drone itself does not or will not light up at all, then some times it stays red, other times its green and other not on at all,
