REPLACED NEW ESC BOARD, THE MOTOR IS VERY HOT
759 2 2015-6-25
saravanavideos
India
AFTER CRASH I HAVE FOUND THAT ESC BOARD BURNT, I HAVE REPLACED WITH NEW ESC BOARD, THE MOTOR IS VERY HOT IN RUNNING AND SPINNING IS NOT PROPER.  I HAVE TESTED 2 MINUTES IN MINIMUM HEIGHT I FOUND BATTERY WARNING APPEARED AND THE PHANTOM AUTOMATICALLY GROUNDED.
PLEASE HELP ME
2015-6-25
roy
If you replaced the ESC and the motor itself is getting hot and not starting and stopping as the other motors then you may need to replace that motor also. The Phantom will autoland when the battery level gets to low. Be sure you start with a fully charged battery.
2015-6-26
saravanavideos
India
roy@mcscomputer Posted at 2015-6-26 18:24
If you replaced the ESC and the motor itself is getting hot and not starting and stopping as the oth ...
thanks for your advice. i have replaced with new motor, now it is ok but the gps not getting please help
thanks in advance
2015-7-10
