Battery Problems
627 6 2020-10-17
djiuser_ezBcngOd0ZEG
Went to fly the Drone while on holidays and noticed that out of the 3 flight batterys that I have only one  fitted the drone as it has done 40 or 50 times before, the other two were very hard to lock in. On closer inspection I have noticed that there is a fair amount of swelling at the back of the batterys and was wondering if anyone else has had this problem as I now have to purchase two new ones and they are not cheap or is there a generic brand that anyone knows of. Any help or advise would be appreciated. Thanks Guys and Gals
2020-10-17
Suren
Flight distance : 13438648 ft
New Zealand
This has become a general problem with the batteries, best would be is to reach out to Dji and hope they replace them for you but don't risk flying with them.
2020-10-17
Blériot53
Flight distance : 6188465 ft
If the batteries are swollen to that extent, they've had it. Don't try to use them whatever you do. And I would stay away from "generic" batteries if such exist. Stick with DJI genuine articles.
2020-10-18
A J
Flight distance : 13926112 ft
Once they are that damaged they become a liability to fly them - you could lose the drone or worse. Not worth the risk.
2020-10-18
DJI Stephen
Hello there. I am sorry to know that you are having issues with the batteries of your DJI Mavic Pro. Battery swelling is basically caused by to much heat, vast changes in temperature and/or moisture getting into the battery itself. The lifespan and condition of the battery will depend on the totality of how it was used and stored. Hoping for your kind understanding that every electronic product and batteries has a certain warranty period and lifespan. For safety purposes please do not use bloated or bulging batteries when flying or operating your drone so that the drone's performance will not be affected or compromised . Using bloated or bulging batteries might lead to damaging of the aircraft, or worse, damage to property. Again I am sorry and thank you for understanding.
2020-10-18
xagoras
Flight distance : 1357589 ft
Greece
This swallwn battery issue is very common with the early 2018 batch, and DJI has silently aknowledged the fact by replacing some of them even though the warrnty period was long gone. Especially if they have a low number of charge cycles.
Best thing to do is to contact their support and then take it from there.
I've personally had one battery replaced like that, manufactured in 08/2018, but I've read about others that didn't have much luck. It's basically a case by case matter for DJI.
2020-10-19
xagoras Posted at 10-19 04:39
I have contacted DJI Support and was told that it is out of warranty and therefore not their problem, I really think it is very bad customer support and believe that if they knew that this batch had problems they should be replaced had a recall and issued new batteries.
2020-10-19
