Issues controller not connecting to mavic 2 pro after update
8416 25 2020-10-18
Castigos
Flight distance : 22057 ft
I had not used my drone in quite a while i turned it on today and it said new firm ware update. Completed the update not it appears the controller cannot connect to the drone. The app says its connected on the first page but when i click go fly it tells me the aircraft is disconnected I've a attached a screen shot
Anyone having this issue?
2020-10-18
A J
Flight distance : 13838848 ft
Refresh the firmware on both the AC and RC using DJI Assistant 2 For Mavic
2020-10-18
DJI Gamora
Hello Castigos. I am sorry to read and to know that you are having issues with your Mavic 2 pro. Were you able to relink the remote to the Aircraft using the DJI Go 4 app or using the combination buttons? For you to have a better visualization of the process, you may refer to this official video tutorial we have for you.
2020-10-19
bjr981s
Flight distance : 139698 ft
As AJ has already said. You must update the drone and controller for every FW update. Some FW updates also require you to update each battery individually.
The best way to do updates is Via DIJ Assistant 2 on your PC or Mac.
2020-10-19
Castigos1985
thanks for the response I tried relinking the controller multiple times however it just tells me controller is link and it still says aircraft disconnected and never connects. Downloaded Dji Assistant on my Mac and using the cable provided with my drone when I bought it I connect it to the computer and dji assistant never picks it up so I  can't even access any other updates I might need to do
2020-10-23
doug86
Flight distance : 309478 ft
I've been flying for months, and about 3 weeks ago, updated all. Everything was fine, until this morning. After powering up, the controller can't link to the aircraft, and repeated attempts with all the binding options fail.  I used the Assistant to update both the aircraft and the controller today, and no luck binding them together. Now what?
2020-10-24
ECL_Wolf
Chile
Hello, I wanted to know if you have had a solution to this, since the same thing has happened to me, I do not have a connection with the controller, and I cannot update the firmware either, the computer does not detect the drone (I already tried several cables and updated the DJi Assistant)
2020-12-30
Castigos
ECL_Wolf Posted at 2020-12-30 15:39
No I wasn’t able to fix the issue , I then called DJI had someone help me I tried everything the person told me with no success he then told me I could send the drone to them which I did and just today I received a “quote for repair” from DJI for 650 dollars which is absolutely absurd  no way should I or anyone have to pay for an issue caused by and update. I
2021-1-7
djiuser_SwWKPiF3pag1
Flight distance : 39626 ft
India
Castigos1985 Posted at 2020-10-23 18:25
Same happened to my dron
2021-2-13
StreamWorks
Nigeria
so wait.. up till now there's no solution for this? why would y'all tell us to update only to destroy our device we got so expensive.... this is fraud meh, and now y'all telling us to pay such huge amount for repairs?
2021-4-15
pauly whitehead
Flight distance : 139721 ft
I did the smart controller update today.  Firmware downloaded & installed just fine.  Controller connected with AC after process.
2021-4-15
glennmurray
Flight distance : 22205 ft
I downloaded the update and now the drone will not connect .Did anyone find a solution .I am not paying for a repair and I can't believe they would try to charge for this .
2021-4-28
Castigos
glennmurray@me. Posted at 4-28 04:40
Update on my end .
Weeks of emails and calls to DJi support supervisors ended in me threatening to file a formal complaint with the BBB (better business bureau) and possible legal action finally did a supervisor called me and told me “after further review we decided to cover your claim”
A load of crap if you ask me they sent me a new drone instead of fixing mine .
You guys should do the same or go ahead and file the complaint and use this forum thread as proof of wrong doing by DJI
Hope this helps you all
2021-4-28
glennmurray
I find this amazing that it has Come to this from an update .
2021-4-28
glennmurray
MY DRONE WILL NOT STOP BEEPING AND FLASHING YELLOW WHEN I PUSH THE BUTTON ON THE DRONE ( WHICH SEEMS TO NOT PUSH ) .ALSO TO MAKE THINGS WORSE MY HAND CONTROLLER SINCE DOWNLOADING THE UPDATE WILL NOT  CHARGE .
how do i get someone to reply here with help as i am on holidays and i want to use my drone ( not thanks to the update ).
2021-4-28
Castigos
glennmurray@me. Posted at 4-28 16:58
Sorry to hear that man. Hope my update helps you
2021-4-28
glennmurray
How do i get tech assistace  from dji ?
2021-4-29
Castigos
glennmurray@me. Posted at 4-29 03:39
Google the tech support number and call
2021-4-29
kyalami
Flight distance : 44914321 ft
Sweden
Press support at the bottom right on this page an select the drone and the the item you wish to have support for.
2021-4-29
mngolfguy
after the update, I had to restart my iphone for the app to connect to the drone
2021-6-2
djiuser_BOrZggELvpTs
Does the Mavic 2 Pro drone/controller linking issue have a solution? Mine has been doing this for a while now even after ensuring the drone, controller and DJI GO 4 App’s are all updated. This drone is essentially useless. Suggestions??
Thank you
2022-5-23
djiuser_BOrZggELvpTs Posted at 5-23 18:21
Thank you
Hello again. Is there any suggestions for the Mavic 2 Pro not linking???
2022-5-29
djiuser_UWlHAHIg2IPV
djiuser_BOrZggELvpTs Posted at 5-29 20:47
Hi mate  my mavic pro 2 has been showing the same problem the light is red and not turning green and not connecting. Did you find a solution for your mavic??
2022-9-13
Alberto Porcaro
djiuser_BOrZggELvpTs Posted at 2022-5-23 18:21
Thank you
ho avuto gli stessi problemi nell'accoppiamento con il Radiocomando. Sia con lo Smart Controller sia con RC1A. Poi la soluzione. Basta effettuare l'accoppiamento lontano da fonti elettromagnetiche. Io provavo in una stanza in cui oltre la pc ho anche il router. Allora sono uscito fuori all'aperto lontano da fonti elettromagnetiche e come per magia ho collegato i radiocomandi sia lo Smart Controller come primario sia RC1A come secondario. Sono ammattito per una settimana e poi tutto risolto. Spero possa essere utile a molti che ho letto sui vari forum.
2023-4-24
Alberto Porcaro
Dimenticavo ho un Mavic 2 pro
2023-4-24
Il-Molla
Malta
Same here Malta, updated and they connect ,but in about 10mts away it drops the antenna signal then disconnects and keeps connecting and diconnecting + RC and aircraft FW doesnt match .
2023-5-4
