schl0r
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
you almost got it 100%. What you're missing in the video is that, where the "0" is missing after the dot, there is a space instead. If you look closely you can see clearly there's a gap between the dot and the next digit.
I observed this many times before. This ONLY happens to a zero digit.
It's still 100% a bug, but what I'm saying is, you can actually tell whether there is a 0 missing (and you gotta add it manually in order to determine the location of your quad if it goes missing) or whether the GPS coordinates are accurate. Also easy to tell if there are less than 7 digits after the dot - then something's fishy with the coordinates.
Bottom line - DJI needs to fix this, and until then, if you see a space character in the lat/long, think of it as a zero. |
