Drone AV
Flight distance : 246650 ft
Thanks for your suggestion.
Lucky me! I finally got the guards out. I slipped in a very very thin metal strip through the tight space between the guards and the rings on the aircraft and they came out.
I will never install the guards in the wrong way, it is painful to get them out.
Also, when I installed in the wrong way, the aircraft refused to move in the air after it had flown a distance. I believe the aircraft sensors must have treated the guards as obstacles. For a moment, I thought I would lose the aircraft. The RC kept beeping on me. I had no glue what to do and what was that meant. The battery was getting low. I finally decided to hit the return home button, and it worked. A very scary moment for me.
Thanks
Sam. |
