Tide
South Korea
While using Pocket 1 for over two years,
I don’t see much reason for dedicated rotation control wheel because you can slightly rotate your arm in follow mode to make the gimbal rotate.
You can have more control using your hand because you can delicately ease in and out the rotation without any accessory.
However if you need a dedicated control, Pocket’s screen has a vertical slider UI you can touch to control vertical rotation. Also connecting to smart phone app, gives you virtual control stick that can control gimbal rotation in every direction.
Pocket 2 comes with physical joystick accessary that can control gimbal movement. You don’t need to purchase separately.
Hope it answers your question. |
