Dji Spark ; Quickshot circle mode fail!
1415 19 2020-10-23
ZotyaDrone
Flight distance : 1510945 ft
Hungary
Hi!
Unfortunately, the spark misses a lot.  In Quickshot circle mode, he always makes a mistake, loses the target and then as if he wants to fly to the target.  The water tower, the transmission tower and other batteries I flew.  If I don't pay attention it can be an accident!
2020-10-23
DJI Paladin
Flight distance : 318 ft
Hello ZotyaDrone, thank you for reaching us out and it is unfortunate to know that your Spark is losing its subject during Quickshot Circle mode.
1. For Quickshot ensure that the GPS connection has good signal, take off the drone and it must be flying at least 1.5 m above the ground.
2. You can tap the Intelligent Flight icon (which is not available in S-mode), 2 select QuickShots. You will then need to select a subject and you will be able to see the four modes you can choose on.
3. Tap the mode again to set distance. After setting, tap the right √
4. Tap “GO” on the screen, and the aircraft will finish the QuickShots in corresponding mode. You can also refer to the link I provided to setup Quickshot. If the issue persist you can contact our product support to provide complete steps: https://www.dji.com/support?site=brandsite&from=nav
Thank you.
2020-10-23
Wolferl
Flight distance : 23793 ft
Austria
HI Zotya,
So true! I have exactly the same problems with the Spark's circle mode. It starts fine, but in the middle it stops it (without a warning!) and returns home.
Always fly higher than the circled object is to avoid crashing.
Hint: do not fly near antenna towers. Their radiation can be very strong and can kill your drone.
Cheers,
Wolferl
2020-10-24
DAFlys
Looks like a great time to learn to fly a circle.
2020-10-24
A J
Flight distance : 13926112 ft
Close encounter there - great flying
2020-10-24
Woe
Flight distance : 4129268 ft
Nice flying. Might be time to upgrade
2020-10-24
ZotyaDrone
Hungary
DJI Paladin Posted at 10-23 13:13
Thanks for the advice and the comment.
I think everything was fine in flight. The gps was right, the compass was also right. Building also loses circle mode.
I'll stick to the manual round flight.
2020-10-24
ZotyaDrone
Hungary
Wolferl Posted at 10-24 00:18
HI Zotya,
Thanks for the advice. Stay in the manual round flight
2020-10-24
ZotyaDrone
Hungary
DAFlys Posted at 10-24 01:23
Yes my friend!
2020-10-24
ZotyaDrone
Hungary
A J Posted at 10-24 01:26
Thanks AJ!
2020-10-24
ZotyaDrone
Hungary
Woe Posted at 10-24 05:18
.900 fw It's on the spark. I understand it's the most stable fw of the spark.
2020-10-24
DAFlys
ZotyaDrone Posted at 10-24 10:29
Yes my friend!
It’s quite easy with some practice.  But like a parallel park if you don’t use it you loose it.
2020-10-24
A J
You're welcome
2020-10-24
Woe
ZotyaDrone Posted at 10-24 10:31
I really can't speak to that, I have never own a spark.
2020-10-24
ZotyaDrone
Hungary
Woe Posted at 10-24 16:14
It's my first dji drone. I like very much the spark, vain little mistakes.
2020-10-24
ZotyaDrone
Hungary
DAFlys Posted at 10-24 11:35
I used to practice circling tripod mode.
2020-10-24
DAFlys
ZotyaDrone Posted at 10-24 23:45
Flying a figure of 8 is quite good fun too.
2020-10-24
Woe
ZotyaDrone Posted at 10-24 23:43
I understand, your first is always the hardest to part with.
2020-10-25
ZotyaDrone
Hungary
Woe Posted at 10-25 04:23
Once there's another drone the spark will stay!
2020-10-25
Woe
ZotyaDrone Posted at 10-25 05:27
2020-10-25
