preparing task with waypoints in no fly area atlow altitude
304 3 2020-10-27
Imker-Jos
Flight distance : 1247 ft
I would like to fly once a week around a location where 100 new houses are going to be build. This location is within a no fly zone.I have permission to fly overthere.
Goal is to make pictures every time from the same position with the camera pointing to the same point of interrest and so ducumenting the progress of the construction.
But when I started to prepare a task for this flight, the message "cannot make this due to the no fly area" popped up.
Does this mean that I cannot use this feature anyway in ths location?
Making it by hand every week will not result in a usefull set of documentaton.
How can I make this task in another way?
I am looking forward to get some hints to solve this....
Jos
2020-10-27
DJI Paladin
Flight distance : 318 ft
Hello Imker-Jos, thank you for reaching out my apologies this has caused you. Have you updated the Fly Safe database. Ensure you have the latest database for Fly Safe.
You can open the DJI Go 4 app and follow the steps below:
1. Enter Camera view then tap the three dots (...) on the upper right corner.
2. Under General Settings, swipe down until you see the "About" section.
3. Find "Precise Fly Safe Database" and along that tap "check for updates"
4. After updating it try to fly your aircraft and use the feature that you want to use.
Please update me with the result. Thank you.
2020-10-27
DAFlys
Ive tried to do this with waypoints before but the images were never the same twice. you might want to just do this manually.  You'll need to request an unlock to fly first though.  https://www.dji.com/uk/flysafe/self-unlock
2020-10-27
Imker-Jos
Thanks a lot! This is working fine now. I prepared a task and will try it tomorrow in the field! Can it happen again, due to the last known position of the drone?
2020-10-27
