lostinthezone
Flight distance : 56732 ft
I have had the same behaviour with the gimbal on my P3, although not nearly as bad as yours. Only 1 flight video showed the 'rocking' motion yours has, but it was probably worse. As for drifting, when it was new I am sure the gimbal did not drift. I don't see any evidence of it in my videos. It worked flawlessly. Now after about 12 flights I am seeing almost constant drifting. If I move the gimbal by hand, it returns to position normally - no drift. If I pick up the P3 (pro), move it around and then set it down, it drifts every single time. It's a very slow drift like about 1 degree every 3 seconds. I have reset the gimbal settings and recalibrated the gimbal several times. I think I will do an IMU calibration next.
Hmm maybe I will check the sensor readings first before doing that.
I put down a sheet of glass on the carpet and used a bubble level with electronic display to accurately level it before doing the IMU calibration. I hope it solves the gimbal drift I am seeing.
Rob
